Buoyancy and gravity
  • Context: High School
  • Thread starter Thread starter TheOldDog
    Buoyancy
32 replies · 8K views
TheOldDog
TL;DR
What are the effects of varying gravity on buoyancy?
Does the draft of a boat change with gravity?
Fairly simple - I think - but I may have missed something; HS physics was decades ago.
If a boat in a body of water on Earth has a draft of 1m, will the draft of the boat in a similar body of water on, say, Mars have the same draft? (Assume the same temperature of water.) I figured the change in water density would be minimal on the surface, even if it's an ocean we're considering.
This originally came up while reading a SciFi book where the 'artificial' gravity was changing but it got me thinking. After reviewing basic buoyancy I don't recall where gravity really played a role. Buoyancy is dependent on the mass of displacement and the mass of the object, right? I don't see where gravity enters into it - assuming there is *some* gravity (not 'weightless').
Any thoughts? Please let me know ...
Reply
TheOldDog said:
TL;DR: What are the effects of varying gravity on buoyancy?
Archimedes' principle is usually expressed in terms of force and weight, not mass, but since the weight of the vessel and weight of the fluid displaced are both proportional gravity…
The pressure of the water is ##p = \rho g h##, so gravity enters through the ##g##. But the force of the water ##pA## (where ##A## is the area) acting upwards has to be balanced by the gravitational force ##mg## acting downwards, so the ##g##'s cancel, i.e. the draft does not depend on gravity.
Reply
What do you mean? there is essentially no bouyancy in microgravity.
Buoyancy is about the weight of the displaced liquid respect to the weight of the boat.
At half gravity intensity, both weights would be cut in half alike.
At increased gravity by artificial means, both weights would be increased at the same rate.
The line of flotation of the boat should remain the same in both scenarios (unless I am wrong).
I mostly agree with the above responses, but I think there are some caveats.
First, is the hull of the boat rigid? The pressure applied by the water will depend on the gravitational field strength, so a flexible hull may change shape when the local ##g## changes. That would change the volume of water displaced, so would affect the draft. (This is actually a plot point in Hal Clements' novel Mission of Gravity.)
Second, does ##g## vary significantly over the scale of the boat? With centrifugal gravity this will happen within a few boat-heights of the spin axis. The different mass distributions of the boat and water it displaces could lead to different drafts then.
I love Mission of Gravity! There was nothing in there that seemed odd at all.
(I thought the use of a bowl instead of the outer surface of a sphere for a map was genius!)
In the SciFi novel I was reading the hull is rigid and the artificial gravity did not vary over the positions covered in the story.
An anti-gravity generator was decreasing the local planet-sized moon's gravity and was supposed to be fixed. A natural disaster was causing many problems, including disrupting the generators, causing the gravity to vary (a little) randomly over time. In the book, the vessel is changing draft as the gravity changes, which just didn't sit right with me when I read it.
So, either I misunderstood something in the story (that I also missed the second time through) or the author needs a review of basic physics. lol
Reply
Exactly my thought at the time. *thumbsup*
(My brain was thinking in weights, which is how I learned it, but when I posted I went to metrics because I know a LOT of science is in metrics these days - much more so than when I was in school back in the stone age.)
I don’t understand the connection between weight versus mass and the use of metric units. The two are independent.
A weight is a force, specifically, a force that results from gravity acting on a mass. Forces and masses can both be expressed in any system of units: cgs, MKS, Avoirdupois, Imperial… cgs and MKS are both metric systems.
In MKS, masses are in kg (the K in MKS), weights are in Newtons.
See https://en.wikipedia.org/wiki/United_States_customary_units#Mass_and_weight.
If ##g## is small but nonzero, then so is ##p=\rho g h##.
Reply
I think it would be a fun experiment to see what happens as you lower the force of gravity. I've watched several 'water' experiments performed on the ISS. While the forces of surface tension can be ignored with boats here on earth, it seems like you would reach some point where at very low values of g, the water might drag the boat under. Unless you had a hydrophobic boat coating.
This one seems to be a good example:
She even mentions surface tension on the moon at around 2:30.
Reply
Clements put a lot of thought into the physics before he wrote that.
In that case I agree with the others.
Reply
I learned this 50 yrs ago. You, yourself, just pointed out the connection between weight and mass.
Or are you saying using the mass of liquid displacement and the mass of the vessel yields different results than using the weight of each ...???
As for why I used mass? Like I attempted to explain earlier, I have NO CLUE after 50 yrs what the hell the scientific education has done to things like Archimedes Principle when so much today is in metric. 50 yrs ago almost nothing in America was metric.
25 yrs ago I had to buy a whole new set of tools (in metric) just so I could work on my car and do DIY projects without running into compatibility issues. I'm surprised I'm not buying 1200x2400 sheets of plywood and (nominal) 5x10 boards by now ...
OmCheeto said:
... it seems like you would reach some point where at very low values of g, the water might drag the boat under.
I see what you mean. But of course, in very low g, the term "under" loses much of its meaning.
I think, essentially, it would be more a matter of the water not being constrained to the lower hull of the boat.
Especially since the water will have lost a meaningful flat surface. Peaks and troughs would become arbitrarily high, breaching the "gunnels".
In your parlance, that is akin to being "pulled under" - but without the "under".
Reply
Yes, there is still a hydrostatic pressure head, but other forces dominate in microgravity- capillary forces, etc. Astronauts lose bone mass because of the lack of bouyancy.
But perhaps the OP was a bad question- imagining a large ship on a larger body of water without gravity present is strange, especially because the body of water will be a sphere. And does water wet the ship hull?
Reply
For a different strength of gravity, atmospheric pressure and hence density would be expected to be different too (unless in a closed container), giving an additional small buoyancy correction that would actually vary with gravity.
Reply
Another variable! The 5 boats I've owned were all made of wood, so no matter how small the non-zero 'g' was, they would all float, regardless of how much water you put in/around them.
As mentioned above, capillary forces will eventually creep into the equation and water will fill/surround the boat. If the boat is denser than water, then I'm pretty sure it would be 'pulled completely under', vs like my boats 'pulled partially under', like an iceberg.
No, I am saying that mass and weight are different entities, but in the context of a fixed acceleration that applies to all the masses involved (gravity, in this case) it won’t matter whether you compare masses or compare weights.
Going metric has no relevance to this discussion. I still do not understand why you even mention it. Can you explain why you think it makes a difference?
Obviously is does make a difference since you complained about me using mass instead of weight. So you need to answer your own question. I personally don't know why you bothered to bring it up in the first place.
Maybe because mass and weight are different in both Imperial units (slugs vs. pounds) and metric units (kilograms vs. newtons)? So why did you bring up the metric system in the first place when discussing mass vs. weight?
YOU brought it up by complaining about my use of mass instead of weight, when you've already conceded that the answer is the same using either one.
How many people do you think are on here that DON"T know that weight and mass are different????
Well, I just must be stupid because I thought I had already answered that question ...
I've done no complaining nor conceding because my very first post in this thread is #20 just above. Do you even bother to check who you're responding to before you shoot off your post?
I definitely did not complain about your referring to mass instead of to weight. I merely pointed out that it is usually quoted in terms of weight. That was relevant to your question because if you state it in terms of mass then you are obviously correct, buoyancy is unaffected because the mass of the vessel and the mass of a given volume of water are the same on any planet.
If you state it in terms of weight then it is a bit more complicated. If we assume the gravitational field is constant then the ratio of the masses is the same as the ratio of the weights, so again, the result is the same on any planet. But, on the large scale, gravitational fields are not uniform.
Consider a planet the size of the Earth but all water, and a uniform density sphere floating on it 1000km in diameter. Say the sphere is so light that its mass centre is above the surrounding water. The planet’s gravity acts more strongly on the region that is displacing water than on the upper portions. As a result, it matters whether we take the principle to be in terms of weights or in terms of masses. Which is right?
The reasoning behind Archimedes' Principle is that if you were to remove the vessel and fill in the hole that leaves in the water with more water then the system would obviously be in equilibrium. It follows that the net force the surrounding water exerts on that hole is the same in both cases. Hence, the weight of water filling the hole is the same as that of the vessel.
For this huge sphere, it means that the sphere's mass would be greater than the mass of the displaced water. Archimedes' Principle only works in a nonuniform gravitational field if you express it in terms of weight.
That still leaves the issue of units of measurement. All the above works whatever system of units you care to use, be it metric, imperial, or Ming Dynasty. Mass and weight are not different systems of units, they are different physical entities. Both have units in metric unit systems and in imperial. They are as different as distance and velocity. Going metric does not replace distances with velocities!
My reply doesn't change regardless of who you are. I already answered the question.
(Ed- Or, I should say, the question has already been answered above.)
Do you even bother to read a whole thread/conversation before replying? Or do you just like jumping blind in the middle?
Reply
  • Sad
Assuming I didn't miss something - which is why I started this thread in the first place. School was a VERY long time ago.
Just tell me weight is not equal to mass times gravity and we can be done ...
Weight is mass times gravity.
I still worry that your post #8, where you imply that going metric involves switching from weight to mass, indicates a fundamental misunderstanding somewhere, but I cannot get you to elaborate on that, so I cannot see how to help further. If I have helped.
Reply
There's no "fundamental misunderstanding" on MY part.
Mass and weight definitions haven't changed in 50 yrs. I went to school when schools actually taught and kids were expected to learn. To me, changing to mass was simplifying the problem because mass doesn't change with gravity but weight does.
But, like I've said many times - including the very first post - I wasn't sure it was that simple. To be honest, I am surprised a SF writer could make such a simple mistake, so I thought maybe it was me. That was the whole point of this thread and could have been answered in one or easy two sentences.
However, to address your "worry" ...
Just tell me it's uncommon in most of the world to refer to my "weight" as xxx kg and you can rest easy. But we ALL know everyone assumes, when talking about weight, that xxx kg IS weight - regardless of the fact that it's really xxx kg of mass @ 1g.
Hardly anyone in the world who uses kg's on a daily basis think about it as mass - they think about it as weight. Do you really believe the rest of the world hardly ever talks about weight, that they're always talking about mass??? Or do you assume, like most people in the world do, that kg is taken as weight regardless of the fact that it was, originally, only used by science and was always mass in that context?
Now, you can explain to me how you think I'm confused when it comes to mass and weight.
I would imagine it's because you wrote this:
...which certainly read to me as if you thought that weight was a concept that was incompatible with metric units, or mass a concept incompatible with non-metric units. After your last post, I think you meant something like "lots of people confuse weight and mass when using metric units, and I wondered if the author had done that and whether it might be important here". If so, I would say that your meaning didn't come across clearly, not least because lots of people can confuse weight and mass in any unit scheme in my experience.
Reply
As I showed in post #23, changing to mass actually made it more complicated because when formulated as a mass equivalence Archimedes principle can be violated in a non-uniform gravitational field, whereas formulated in terms of weights it always works.
What mistake? I don’t see anywhere in the thread where you mentioned such.
It would certainly be wrong in a technical context to quote a weight in kgs. The correct unit in the present international standard metric system (“MKS”) for a force is the Newton. If the acceleration due to gravity is 9.81m/s2 then a mass of 1kg has a weight of 9.81 Newtons.
TheOldDog said:
But we ALL know everyone assumes, when talking about weight, that xxx kg IS weight - regardless of the fact that it's really xxx kg of mass @ 1g. … Hardly anyone in the world who uses kg's on a daily basis think about it as mass - they think about it as weight.
Right, but we’re discussing scientific use.
Because in post #8 you wrote:
TheOldDog said:
My brain was thinking in weights, which is how I learned it, but when I posted I went to metrics because I know a LOT of science is in metric.
From that, it certainly seems that you think going to metric means you have to switch from referring to weight to referring to mass. Did you think that? Do you still think that? If you did not think that, what did you mean?
Post #7
Assuming everyone here actually understands that.
50 yrs ago that's what we did in school. When we used mass it was in grams, when we used weight it was in pounds. So, yes, to me switching to mass meant metric (g) by default.
That doesn't mean I believe a ~220# crate shipped to (nominal) orbit would be as easy to maneuver as a feather on Earth even though the crate probably weighs about as much as a feather up there. It's still ~100kg; hard to start moving and hard to stop ...:rolleyes:
