Buoyancy force of a hot-air balloon
The discussion revolves around the buoyancy force of a hot-air balloon, specifically calculating the maximum mass of passengers it can carry given the balloon's dimensions and the temperature of the gas inside. The problem involves concepts from fluid mechanics and thermodynamics, particularly the behavior of gases under varying temperatures and the principles of buoyancy.
  • Participants discuss the calculation of the buoyant force and the density of the air inside and outside the balloon. There are attempts to clarify the meaning of variables such as the number of moles and the density used in calculations. Questions arise regarding the assumptions made about the gas properties and the conditions under which the calculations were performed.
The discussion is ongoing, with participants seeking clarification on the calculations and concepts involved. Some guidance has been offered regarding the relationship between the buoyant force and the weight of the balloon, as well as the importance of distinguishing between the densities of air inside and outside the balloon. There is a recognition of the need to balance the weights involved in the problem.
Participants express uncertainty about the calculations related to the number of moles and the densities used. There is a mention of a previous similar question, indicating a potential confusion stemming from different conditions or parameters. The discussion reflects the complexities of applying ideal gas laws in varying temperature scenarios.
smeiste
The envelope and basket of a hot-air balloon have combined mass of 331 kg. The spherical envelope of the balloon has a radius of 10 m when fully inflated. What is the maximum mass of the passengers the balloon can carry when the temperature of the gas is 108 o C? Use M(air) = 29 g/mol. Assume that the surrounding air is at 25 o C and is treated as an ideal gas.
Fbuoyancy = ρVg (density times volume times acceleration due to gravity)
Not entirely sure if a buoyant force is acting here, but it makes sense as that's what we're learning.
Attempt:
Volume at 25 degrees = 4/3πr^3 = 4188 m^3
(101330Pa)(4188m^3) = n (8.314)(298K)
n = 171317 moles
(171317mol - n hotair) = (171317mol)(298K)/(381K)
n hotair = 37321 mol
171317 - 37321 = 133995 mol
(133995mol/m^3)(0.029kg/mol) = 3885 kg/m^3
Now assuming that is the density, I was trying to plug that into the buoyancy formula and calculate the force. However my force ends up way too big. The correct answer in the end should be 751 kg. Any help is appreciated!
Hi smeiste,
I can not follow your work...
n = 171317 moles
Could you please explain what you calculated?What are n and n hotair?
What density did you use when calculating the buoyant force?
ehild
umm n is the number of moles. n hot air is the number of moles in the balloon at 108 degrees Celsius. I'm not entirely sure what exactly I did haha. and I used the density I calculated 3885 kg/m^3. I probably did it all wrong
It is not sure you did it wrong, try to explain.
Number of moles of what?
Yes but the density of what? OK, air, but inside the balloon or outside? At what temperature?
ehild
i honestly have no idea what moles I calculated.. There was a similar question only it wanted the temperature inside the balloon and I tried to do a similar thing. I don't really understand what density I calculated either.
The balloon rises or at least it does not fall down so its weight must be balanced by the buoyant force: The weight of the whole balloon with the gas inside and with the load must be balanced by the weight of the air displaced.
The volume of the air inside the balloon is the same 4000pi/3 m3 as the volume of the air displaced, but the temperature of the air in the balloon is 381 K and that of the displaced air is 298 K. The same amount of air consist of less molecules inside the balloon than outside. You calculated the number of the displaced moles - that was n, and the number of the moles inside the balloon that was n(hotair). Multiplying n(hotair) with 0.029 kg/mol gives the mass of the gas inside the balloon; multiplying n by the same 0.029 kg/mol gives the mass of air displaced.
Write out the equation for the balance of the weights.
ehild
ohh i see. I just went too far with the problem haha. Thank you!
