Calculating Specific Gravity and Density of a Body
The discussion focuses on calculating the density and specific gravity of a body weighing 100 N in oil with a density of 0.8 g/cm³ and 60 N when immersed in water. The solution provided is 1.3 g/cm³. The participant attempted to use the formula for apparent weight, defined as actual weight minus buoyant force, but did not achieve the correct result. Detailed steps and reasoning are required to clarify the misunderstanding in the calculations.
  • Understanding of buoyancy and Archimedes' principle
  • Familiarity with the concept of apparent weight
  • Knowledge of density calculations
  • Basic algebra for solving equations
  • Review Archimedes' principle and its applications in fluid mechanics
  • Study the calculations for buoyant force and its impact on weight
  • Learn how to derive density from weight and volume measurements
  • Explore specific gravity and its relationship to density
Students in physics or engineering, educators teaching fluid mechanics, and anyone interested in understanding buoyancy and density calculations.
Poquinha
If you have a body that weighs 100 N dipped in oil that has density equal to 0.8 g / cm³. This same body when immersed in water begins to weigh 60 N. How do I find the density / specific body mass?
Solution= 1,3 g/cm³
Already tried using the formula of the apparent weight = actual weight - buoyant and not worked.
You'll have to show details of your attempt. How do you know it didn't work?
11K
