How much sea water is needed to keep a submarine still at 30 meters depth?
The discussion centers on calculating the amount of sea water needed to fill a submarine's water tank to maintain neutral buoyancy at a depth of 30 meters. The submarine has a volume of 125 m³ and weighs 123 tons. The correct density of sea water is established as approximately 1.03 x 10³ kg/m³, which is crucial for accurate calculations. The conclusion indicates that to achieve neutral buoyancy, approximately 56% of the 10 m³ water tank must be filled with sea water, correcting earlier miscalculations based on an incorrect density value.
  • Understanding of Archimede's principle
  • Basic knowledge of fluid density calculations
  • Familiarity with buoyancy concepts
  • Ability to perform volume and mass calculations
  • Research the effects of pressure on buoyancy in fluids
  • Learn about the properties of sea water density variations
  • Study advanced applications of Archimede's principle in engineering
  • Explore submarine design principles related to buoyancy control
Students studying physics, marine engineers, and professionals involved in submarine design and operations will benefit from this discussion.
tuki
A submarine is in water, depth 30 meters. Inside submarine there is default air pressure. Submarine has volume of 125 m³, from which 10 m³ is water tank used for submerging. Submarine weights 123 tons. How large portion of the water tank has to be filled with sea water in order to stay still?
Density:
$$ \rho = \frac{m}{v} $$
By comparing densities we can determine if a object in fluid is sinking, floating or staying still. If
$$ \rho_{\text{obj}} > \rho_{\text{fluid}} \implies \text{sinking} $$
$$ \rho_{\text{obj}} < \rho_{\text{fluid}} \implies \text{floating} $$
$$ \rho_{\text{obj}} = \rho_{\text{fluid}} \implies \text{staying still} $$
. This can be derived from Archimede's principle.
Now we want density of the submarine to be equal to density of water. Which means it stays still in relation to the water. In following equation left hand side (density of submarine), right hand side (density of water). M = mass of submarine, m = mass of water in the tank, v = volume of the submarine.
$$ \frac{M+m}{v} = \rho_{\text{v}} $$
Mass of the water can be expressed as $$m = \rho_{\text{fluid}}v_\text{water in tank}$$
$$ \frac{M+\rho_{\text{fluid}}v_\text{water in tank}}{v} $$
$$ \implies v_\text{water in tank} = v-\frac{M}{\rho_{\text{fluid}}} $$
By computing this we will have
$$ v_\text{water in tank} \approx 1.63 \text{ m}^3 $$, which is 16.3% from the 10 m³ tank. Correct answer would be 56% of the 10m³ tank. Can't exactly see what I'am doing wrong?
why would they tell you about this air pressure ?
what is the density of sea water you used ?
The deeper you go the greater the pressure caused by water is. More water above submarine => greater pressure. I don't see how this would affect the buoyancy of the submarine? The force caused by pressure is distributed evenly on top, bottom and sides of the submarine, meaning the sum of the forces is zero? => these forces do not affect if the ship sinks or not. I think i lack the knowledge on how the Archimede's principle is related to pressure?
And the sea water density is used is 997kg/m³
That's the problem. This is not the same density as the one used to obtain 56%.
Yes i think it's suppose to be 1.03*10^3 kg/m³. There is mistake in the description of the assignment.
That appears to be the correct value. 997 kg/m3 is a bit low for sea water, which is mostly in the range 1020-1030 kg/m3.
and my post was to make you see that 125 or 115 m3 of air is only a small mass -- (almost?) negligible
the sea water density is the main dish (and works in the other direction)
11K
