Do Buoyant Forces Depend on the Material's Density?
The buoyant force acting on a submerged object is determined solely by the volume of liquid displaced and the density of the liquid, not the density of the object itself. In this discussion, a 20cm³ block of lead and a 20cm³ block of copper are both submerged in water, resulting in equal buoyant forces despite the differing densities of the materials. The calculations confirm that the buoyant force is the same for both blocks, as it is based on the formula Fb = Vρg, where V is the volume of liquid displaced and ρ is the density of the liquid. Therefore, the correct conclusion is that the buoyant force is independent of the material's density.
  • Understanding of Archimedes' principle
  • Familiarity with the formula for buoyant force (Fb = Vρg)
  • Knowledge of density and its units (kg/m³)
  • Basic physics concepts related to forces and equilibrium
  • Study Archimedes' principle in detail
  • Learn about the properties of fluids and their densities
  • Explore applications of buoyant force in real-world scenarios
  • Investigate the effects of shape and volume on buoyancy
Students studying physics, educators teaching buoyancy concepts, and anyone interested in understanding fluid mechanics and the principles of buoyancy.
wondermoose
A 20cm^3 block of lead and a 20cm^3 block of copper are completely under water. Each is suspended by a thread so that they both hand at the same height in an aquarium filled with water. Which of the following is true?
a) The buoyant force is greater on the lead than on the copper
b)*** The buoyant force is greater on the copper than on the lead
c) The buoyant force is the same on both blocks
d) More information is needed
Fb=\rhovg
This problem was on a test and I was pretty sure the correct answer was B, but I was wrong. My revised way of thinking about it is since the volume is the same then the material with the greater density should have the larger buoyant force.
\rholead=11300 kg/m3
and
\rhocopper=8920kg/m3
Soooo
Flead = (11300 kg/m3)(.020 m3)(9.8 m/s2)
= 2214.8
Fcopper = (8920kg/m3)(.020 m3)(9.8 m/s2)
= 1748.3
Flead > Fcopper
Make sense? Thanks!
I think you have some misconceptions here.
Buoyant Force = Vρg, the V is the volume of liquid displaced, p is the density of the LIQUID displaced.
Hence, the upthrust is the same for both, since in both cases, the liquid and the volume of liquid displaced is the same.
Now, you might ask why is it that both can be at the same height at the water even though the lead block is obviously heavier than the copper block.
This is because Buoyant force + Force exerted by the string = Weight of block.
So does that mean the buoyant force is the same for both blocks, regardless of the density of the material? I guess that makes sense, since both blocks are the same dimensions under the same circumstances.
Just to make sure I'm getting this (because I obviously didn't before):
The buoyant force is the same on both blocks because buoyant force is independent of the density of the material.
Yes. That's correct.
  • · Replies 18 ·
  • · Replies 18 ·
