C++ code not compiling correctly
  • Context: C/C++
  • Thread starter Thread starter Benzoate
    C++ Code
3 replies · 4K views
Benzoate
I'm pretty sure I wrote the correct code for the quadratic formula and yet Dev-C++ continues to find a problem with my code. I will post the code I've written:
#include<iostream.hpp>
#include<math.h>
int main()
double root1,root2,a,b,c,root;
count << "Enter the coefficients a,b,c: "; ! This is the line where Dev-C++ finds an error
cin >> a >> b >> c;
root=sqrt(b*b-4.0*a*c);
root1=.5*(root-b)/a;
root2=-.5*(root-b)/a;
count << "The solutions are " <<root1 << " and " <<root2 << "\n";
return(0);
You need either std::count or put a "using namespace std" declaration at the top.
You might want to try the C++ math library instead:
#include <iostream>
#include <cmath>
using namespace std;
I found this here. You might want to glance over it.
http://forums.devshed.com/c-programming-42/using-std-namespace-what-does-it-mean-45679.html
As others have pointed out, there are a couple of mistakes. First, functions such as cout, cin, and so on belong to the standard namespace in C++. So if you want to use them in your code you need to do one of two things. The first option is to precede every call to these functions with a declaration that they're from the standard namespace, i.e., instead of
Code:
cout << "This is some text..." << endl;
you should have
Code:
std::cout << "This is some text..." << std::endl;
However, typing std:: each time you call a function from the C++ standard library is cumbersome. Therefore, you can save time by using the following as a preprocessor directive in your code:
Code:
Typically, you should declare all of the parts of the standard library that your code needs and then include "using namespace std;" on the next line.
The other difficulty is that you should use the cmath library instead of the math library. Both are essentially identical apart from the fact that cmath allows its members to be placed in the standard namespace. So your code should really look like this:
Code:
#include <iostream>
#include <cmath>
int main()
  double root1,	root2, a, b, c,	root;
  cout << "Enter the coefficients a, b, c: " <<	endl;
  cin  >> a >> b >> c;
  root = sqrt (b*b - 4.0*a*c);
  root1 =	.5*(root - b) / a;
  root2 =	-.5*(root - b) / a;
  cout << "The solutions are:" << endl
       << "root1 = " <<	root1  << endl
       << "root2 = " <<	root2
       << endl;
  return 0;
