C++ object accessing another object's data members
  • Context: Comp Sci
  • Thread starter Thread starter butterfli
    Data Members
6 replies · 8K views
butterfli
see #3
N/A
I'm working on this assignment and I got stuck at this part in programming here's what I need to do:
I need to find a way to have one object access the data members of another object.
A broken down/simplified version of my code looks like this:
Code:
class ClassOne
public:
	ClassOne();
	int m_SomeData;
	string getData();
ClassOne::ClassOne()  //setting data to 1
	m_SomeData = 1;
string ClassOne::getData()
	return m_SomeData;
What I want to do is:
Code:
class ClassTwo
public:
	void showData();
};void ClassTwo::showData()
	//pseudocode: cout << m_SomeData from ClassOne;
	//how do I get this line to work?
I know I have to pass in parameters to showData() and possibly dereference but I don't know what to pass in.
ClassOne is public, and so are its data members. If you create a ClassOne object, any other class has full access to the data and methods on ClassOne. To do what you want to do, I would write showData so that it has a parameter that is a reference to a ClassOne object.
In practice, though what you are trying to do is very seldom done, and is to be avoided. The data members of a class are usually declared using the private or protected access specifier, not public. Making the data private promotes encapsulation via data hiding.
Can you show me how that code looks? I know I sound like I'm asking to be spoon-fed but the textbook I have does not have those examples.
Code:
void classTwo::showData(ClassOne & classOneobj)
   // code for method
Inside this method you can call getData or evaluate m_someData directly.
Code:
   cout << m_SomeData;
My compiler wants me to declare m_SomeData in classTwo because it's giving me an undeclared identifier error. I thought passing in parameters (ClassOne & classOneobj) was suppose to eliminate the need to do that...?
m_SomeData is out of scope, so you can't use it that way. The idea of passing in a parameter to a function is to actually use the parameter, which you haven't done.
If you have an instance of a class, how do you use a method or property on that object?
Oh, duh.
Code:
void ClassTwo::showData(ClassOne & classOneobj)
   classOneobj.getData();
Thank you.
One last question:
Code:
int main() {
	ClassTwo dummy;
	dummy.showData();
	return 0;
dummy.showData(); wants parameters passed into it. What would they be?
Parameters with data types like strings and ints, I know to pass in strings and ints
void someFunction (string someString)
someObject.someFunction("this is a string");
But what would the parameters for a reference be?
Edit: I tried doing: dummy.showData(ClassOne & dummy); but coming back with an "illegal use of expression" error.
Edit 2: Okay, I got it. It should be
Code:
int main() {
	ClassTwo dummy;
	ClassOne dummy1;
	dummy.showData(dummy1);
	return 0;
Thank you for everything Mark.
