C/C++ How to Implement Polynomial Operations in C++?
The discussion focuses on implementing polynomial operations in C++ through a class called QuadraticPolyonym, which represents a second-degree polynomial. Key features include creating a constructor to initialize coefficients, implementing a method to calculate the discriminant, and providing a method to find the roots of the polynomial using a dynamic array. Additionally, operator overloading for polynomial addition is discussed, requiring a global function to sum two QuadraticPolyonym instances. Participants emphasize the importance of adhering to object-oriented programming principles and correctly structuring the class and its methods for functionality.
mathmari
MHB
Hey! :giggle:
I am looking at the following:
a) Create a class QuadraticPolyonym that describes a polynomial of second degree, i.e. of the form $P(x)=ax^2+bx+c, a\neq 0$.The coefficients have to be givenas arguments at the construction ofan instance of the class. Implement a method Discriminant that calculates the discriminant $D=b^2-4ac$.
b) Implement a method Roots that returns a dynamic array (std::vector) with the real roots of $p(x)=0$.
c) Support addition of polynomials with the operator $+$. With elements QuadraticPolyonym p1, p2; thepolynomial QuadraticPolyonym p3 = p1 + p2; should describe a polynomial where the coefficients isteh sum of the corresponding coefficients of the polynomials p1 and p2.
d) Write a program that creates two elements of the class QuadraticPolyonym P(x) and Q(x) reading the coefficinets from the input, adding these to get the polyomial R(x) and printing the roots of R(x)=0$ at the output.I have done the following :
Code:
#include <iostream>
#include <string>
#include <cstring>
#include <cmath>
#include <vector>
using namespace std;
//Question(a)
private:
    double a, b, c;
public:
double Discriminant(double a, double b, double c) { return b*b-4*a*c; }
//Question (b)
double Roots(double a, double b, double c)
int x1, x2;
   if (Discriminant(a,b,c) > 0) {
        x1 = (-b + sqrt(Discriminant(a,b,c))) / (2*a);
        x2 = (-b - sqrt(Discriminant(a,b,c))) / (2*a);
        cout << "Roots are real and different." << endl;
        cout << "x1 = " << x1 << endl;
        cout << "x2 = " << x2 << endl;
    else if (Discriminant(a,b,c) == 0) {
        cout << "Roots are real and same." << endl;
        x1 = -b/(2*a);
        cout << "x1 = x2 =" << x1 << endl;
    else {
        cout << "Roots are complex"  << endl;
    return 0;
//Question (c)
double* OperatorPlus(double x[3], double y[3])
double* z=new double[3];
int i;
    for( i = 0; i < 3; ++i) {
        z[i] = x[i] + y[i];
    return z;
}};//Question (d)
int main()
QuadraticPolyonym R;
int i;
double coefP[3], coefQ[3],result[3];
cout<<"Enter the coefficients of P:\n";
for(i = 0; i < 3; i++) {
    cin>>coefP[i];
cout<<"Enter the coefficients of Q:\n";
for(i = 0; i < 3; i++){
    cin>>coefQ[i];
double* result = R.OperatorPlus(coefP, coefQ); //Question (c)
R.Roots(result[0],result[1], result[2]);
return 0;
It doesn't work as it should yet, but am I thinking in a correct way for the program? Or is this completely wrong? :unsure:
Technology news on Phys.org
Hey mathmari!
It says: The coefficients have to be given as arguments at the construction of an instance of the class.
That means there should be a constructor function named QuadraticPolyonym() with 3 parameters that initializes each of the 3 data members a, b, and c.
It should be used to construct p and q in main() like:
double a, b, c;
cin >> a >> b >> c;
QuadraticPolyonym p(a, b, c);
cin >> a >> b >> c;
QuadraticPolyonym q(a, b, c); 🤔
It says: Implement a method Discriminant.
That means there should be a method named Discriminant() without any parameters that should calculate the discriminant based on the 3 data members a, b, and c.
It should be called in main() like:
cout << "Discriminant P=" << P.Discriminant() << endl; 🤔
It says: Implement a method Roots that returns a dynamic array (std::vector).
That means there should be a method std::vector Roots(); without any parameters that returns an std::vector with the roots. 🤔
It says: Support addition of polynomials with the operator +.
That means there should be a global function QuadraticPolyonym operator+(const QuadraticPolyonym& p, const QuadraticPolyonym& q) that adds p and q together and returns the result.
It should be called in main() as specified in the problem. 🤔
It doesn't say how to read/print the polynomials for (d), so what you have in your main() is okay to read the coefficients.
But we should still construct the polynomials and use the methods we have to process them. 🤔
double a, b, c;
cin >> a >> b >> c;
cin >> a >> b >> c;
What exactly should this constructor function do? I got stuck right now. :unsure:
Is the part in the class where I defined the discriminant wrong? ;unsure:
Should it be :
Code:
std::vector Roots()
int x1, x2;
   if (Discriminant(a,b,c) > 0 || Discriminant() == 0) {
        x1 = (-b + sqrt(Discriminant())) / (2*a);
        x2 = (-b - sqrt(Discriminant())) / (2*a);
        return {x1,x2}
    else {
        return 0;
:unsure:
I changed now some things... Now I have:
Code:
#include <iostream>
#include <string>
#include <cstring>
#include <cmath>
#include <vector>
using namespace std; class QuadraticPolyonym
private:
    double coef[3];
public:
double Discriminant() {return b*b-4*a*c; } std::vector Roots()
int x1, x2;
   if (Discriminant() > 0 || Discriminant() == 0) {
        return {x1,x2}
    else {
        return 0;
double QuadraticPolyonym::getCoef( int k ) const
   if ( k <= 2 )
      return coef[k];
   else
      return 0.0;
void QuadraticPolyonym::setCoef(int k, double value)
   coef[k] = value;
}//-- Definition of +
QuadraticPolyonym operator+(const QuadraticPolyonym & P, const QuadraticPolyonym & Q )
   double sum;
   for ( int i=degree; i >= 0; i-- )
      sum = P.getCoef( i ) + Q.getCoef( i );
      if ( sum != 0.0 )
         R.setCoef( i, sum );
   return R;
int main()
QuadraticPolyonym P,Q,R;
int i;
double coefP[3], coefQ[3];
    cin >> x;
    P.setCoef(i,x);
} cout<<"Enter the coefficients of Q:\n";
    cin >> x;
    Q.setCoef(i,x);
R=operator+(&P, &Q);
R.Roots();
return 0;
I still get some errors. But is this now on the correct way? :unsure:
You still don't have a constructor!
It's been a long time since I wrote C++. I prefer Pascal- but they aren't that different.
I think you need something like
class QuadraticPolynym
private
double a, b, c;
QuadraticPolynym(double p, double q, double r)
{ \\constructs the polynomial x^2
a= p; b= q; c= r;
This QuadraticPolyonym exercise and the previous one about Matrix33 are about solving problems with Object Oriented Programming in C++.
That means learning about:
  • Classes
  • Constructors/destructors
  • Data members/member functions (aka methods)
  • public/protected/private access
  • operator overloading
To achieve that we need to solve the problems as is specified. (Sweating)
So for instance in (c) we need to have the code in main() that is like:
Code:
That is to learn about operator overloading and we're supposed to figure out how to make it work. 🤔
The constructor of the class is written in the same way as it was for Matrix33, which Country Boy also highlighted.
Its purpose is to initialize a new instance of a class based on some parameters.
In this case the parameters of the public constructor must be copied to the private data members of the class. 🤔
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
  • · Replies 23 ·
12K
  • · Replies 22 ·
  • · Replies 35 ·
  • · Replies 17 ·
  • · Replies 39 ·
  • · Replies 36 ·
