What is the output of this C program with int pointers?
The discussion focuses on analyzing a C program that uses integer pointers and character arrays. The code allocates memory for character pointers and processes a string, converting character digits to integers for indexing. Key points include the distinction between accessing array elements directly versus converting character values to integers, which is crucial for correct indexing. The program's handling of memory allocation and pointer types raises concerns about potential crashes when accessing invalid memory. Overall, the analysis clarifies the program's behavior and the importance of understanding pointer types in C.
diredragon
I am supposed to analyze the code and find it's output without running it. Some things were unclear so i did run it and i have some things that puzzle me.
3. The Attempt at a Solution [/B]
C:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
enum e {N1=5, N2, N3, N4};
void main() {
   char *a, *b, *c, i, j;
   int n = 0;
   a = (int*)calloc(N2, sizeof(char));
   b = c = (int*)malloc(N4 + 1);
   strcpy(b, "31131402");
   //not sure what happens in the next few lines.
   //a is an int pointer allocated to 6 char places.
   while (*c) {
       a[*c++ - '0']++;
       n++;
       //first itteration *c = '3'
       //a['3' - '0'] = 0 because it's post increment
       //second itteration *c = '1'
       //a['1'-'0'] = 1
       //third itteration *c = '1'
       //debugger gives a[*c++ - '0'] as 1 again?
       //third itteration gives a[*c++ - '0'] = 1 and fourth a[*c++-'0']=0;
       //how to it assign them like this? It has something to do that it's int pointer with 6 char places but i can't seem to grasp why.
       //how does it do it?
   for(c = a; *c; printf("%c", *c++ + 'a'));
   printf("\n");
   free(a); free(b);
a, b and c are defined as pointers to char. Even if your compiler accepts a = (int *) calloc( ... ), a will be a pointer to char and the cast won't do anything.
The while loop just scans the string "31131402" using the pointer to character c, until the ascii zero at the end of the string is reached.
a[*c++] is not the same as a[*c++ - '0']. '0' is subtracted from *c to convert the chars '0' .. '9 with ascii codes 48..57 to the ints 0..9.
Using a['0'] should cause a crash.
Likes diredragon
Thanks, i understand that know :)
  • · Replies 17 ·
