C++ User-defined function to calculate the smaller string?
1 reply · 4K views · last reply
Absolutism
I came across some codes that calculate the smaller string using user-defined functions.
I tried figuring them out, but some parts I don't get. This is the first one:
bool isShorter (string& s1, string& s2) { // the string objects may be large!
return s1.size( ) < s2.size( ); // checks whether the first string object is shorter
} // then the second: no need to copy the strings
int main ( ) {
string A(“Hello, “); string B(“John!”);
if ( isShorter (A,B) )
count << “The shorter string is: “ << A << endl;
else if ( isShorter (B,A) )
count << “The shorter string is: “ << B << endl;
else count << “The two strings are of equal length” << endl;
That part in bold, I don't get. Isn't that a bool? and it should return true/false? Besides, should we not account for the condition of s2 being smaller than s1 too?
The other question is basically about a similar code, put in a different way.
That is the function:
bool isShorter (const string& s1, const string& s2) {
I don't get the use of "const" here. Can someone explain?
This is the main:
int main ( ) {
count << “String “ << A << “ is shorter than “ << B << endl;
if ( isShorter (“Hello, “, “John!”) )
count << “The shorter string is: “ << “Hello, “ << endl;
I have tried to write a similar program using strings, which should be pretty simple:
#include "iostream"
#include "string"
using namespace std;
string isShorter (string s1, string s2)
if (s1.size() <s2.size())
return s1;
else
return s2;
int main ()
string x;
string y;
string z;
getline (cin, x);
getline (cin, y);
z=isShorter (x,y);
count<<z;
return 0;
But I was told that this way, it is not efficient for larger strings.
int main ( ) {
cout << “The shorter string is: “ << A << endl;
cout << “The shorter string is: “ << B << endl;
else cout << “The two strings are of equal length” << endl;
That part in bold, I don't get. Isn't that a bool? and it should return true/false? Besides, should we not account for the condition of s2 being smaller than s1 too?The other question is basically about a similar code, put in a different way.
} // then the second: no need to copy the stringsI don't get the use of "const" here. Can someone explain?
This is the main:
int main ( ) {
cout << “String “ << A << “ is shorter than “ << B << endl;
cout << “The shorter string is: “ << “Hello, “ << endl;
#include "iostream"
#include "string"
return s1;
else
return s2;
int main ()
string x;
string y;
string z;
getline (cin, x);
getline (cin, y);
z=isShorter (x,y);
cout<<z;
return 0;
I want to make a general statement first. It is often good to give pieces of code names to clarify meaning. In these pieces of code, they try to do that with isShorter(). But in my opinion, that function actually obscures meaning through over-complication. I had to look back constantly at the function definition to see if isShorter(a,b) checked whether a was shorter than b or if it checked whether b was shorted than a. It would have been simpler (and more understandable to me) if the code simply put the one-liner length comparison in main.
As for your first question, that is indeed a bool aka true or false. But it isn't the entire program. It is merely a piece of reusable code that is jumped to from main. In other words, in the code encased by "int main{}", wherever you see isShorter(string1, string2), the code communicates the contents of string1 and string2 to the code in isShorter, runs the code in isShorter, and then returns that Boolean result. So an equivalent program would be:
Code:
int main ( )
if ( A.length < B.length )
else if ( B.length < A.length )
else
As for your second question, you can send data (e.g. a string) to a function by reference or value.
If I sent it by value, the function has "randomFunction(string willBeValueOfString)" and main can send the contents of aString with "randomFunction(aString)". In this circumstance, it takes the computer some time to replicate each entry in aString to give to randomFunction. This makes it slower for larger data sets. But there is a benefit to the decrease in speed: randomFunction can demolish the data it receives etc. without main's aString changing at all! Main, after all, made a copy and gave it to randomFunction for this security.
If sent by reference ("randomFunction(string& willBeRefOfString)"), main actually sends directions to the same data that main is using. If main does randomFunction(aString), when main gets back in control, aString can actually have different values from when it called randomFunction. For example, it could send "frog" to randomFunction only to have "abcd" be in aString afterward. Despite this potentially bad possibility, it has a benefit: There is no replication of data, so it is faster than sending by value for large data sets. (Note, the potential changing of data with a pass by reference can be used beneficially if, for example, you use an input argument actually as an output -- as in, main says, "Here is aString. Please put into it what I expect you to put in there.")
Summary: Sending by value has data security for main but can be slower. Sending by reference has no data security yet can be faster. I have not tested it, but if you send a single integer, it makes sense that a pass by value or reference will take the same amount of time, explaining my careful wording of "can be" faster or slower.
So what if you want the potential added speed of sending by reference without the potential destruction of your data? You know 100% that the function has no reason to change your data, but unless the c++ environment makes it 100% certain it will not happen, you don't feel safe giving it your precious data. What you do here is in your function, pass a constant reference. So you send directions to the data still, hence being possibly faster than a pass by value, but the function cannot change the values of aString. If it ever tries to change it in the source code, you will get a compiler error. It will never be a run-time issue.
In sum, a pass by constant reference is proper if you send the contents of some variable by reference without the intention of changing the values of that variable relative to the caller by the callee (e.g. keep aString in main the same after calling randomFunction). Further, it is customary to pass argument by reference if you are dealing with something that has more than one value in it such as a string.
