C# Windows Forms block not responding to arrow key input
7 replies · 7K views · last reply
TheDemx27
C# Windows Form "Game": Movement
All I wanted to do was to make a block move right/left across the window. I'm using VS 2010. No compiler errors and when I run it, it doesn't respond to any input.
Code:
using System;
using System.Windows.Forms;
namespace Game
    public partial class Form1 : Form
        bool right;
        bool left;
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
        private void timer1_Tick(object sender, EventArgs e)
            if (right == true)
                player.Left += 5;
            if (left == true)
                player.Left -= 5;
        private void Form1_KeyDown(object sender, KeyEventArgs e)
              if (e.KeyCode == Keys.Right)
                    right = true;
                if (e.KeyCode == Keys.Left)
                    left = true;
                if (e.KeyCode == Keys.Left && e.KeyCode == Keys.Right)
                    right = false;
                    left = false;
        private void Form1_KeyUp(object sender, KeyEventArgs e)
                    right = false;
                    left = false;
Code:
using System;
namespace Game
        bool right;
        bool left;
        public Form1()
            if (right == true)
                player.Left += 5;
            if (left == true)
                player.Left -= 5;
                    right = true;
                    left = true;
                    right = false;
                    left = false;
                    right = false;
                    left = false;
As far as I can tell from the code that you showed, when the KeyUp or KeyDown events are raised, all that happens is that you're setting the right or left variable, depending on what key has been set. I don't seen any code that actually causes something to move.
You need to start the timer. You can do it like:
Code:
            timer1.Start();
I think that code is here:
Code:
            if (right == true)
                player.Left += 5;
            if (left == true)
                player.Left -= 5;
It should work assuming that the player is visible and the timer is on.
Sorry: "player" is just a picture box in form1.
Code:
            timer1.Start();
Thanks!
See this assignment: http://harbormist.com/cit597_11/asgn/02_bubblebox.html It's about the simplest code for animation that one can write. Note that you don't actually draw (or move) things in the timer routine itself--you only invalidate the form so that it can redraw itself--and then, to tell it how to redraw, you need to do things by overriding the form's OnPaint method.
At least, that is the way that Microsoft recommends you do it.
