Cable to be used for the suspension bridge
The discussion revolves around calculating the shortest length of a cable for a suspension bridge that can support a tension of 40 MN. Participants explore the relationship between cable length, sag, and loading conditions, considering both theoretical models and practical assumptions.
  • Homework-related
  • Nathaniel seeks guidance on finding the sag or length of the cable, indicating a lack of equations or direction.
  • One participant suggests that the cable can be modeled as a catenary and provides a link for further reading.
  • Another participant questions the loading conditions of the cable, asking for clarification on whether the supports are at the same elevation and if any information has been omitted.
  • Nathaniel confirms that both supports are at the same height and assumes a uniformly distributed load, providing a link to a diagram.
  • A participant notes the importance of knowing the cable weight and the uniformly distributed load from the bridge's deck, explaining that cables under their own weight form a catenary, while a parabolic shape can be used when the sag is small compared to the span.
  • Another participant states that the problem has infinite solutions given the limited information, emphasizing the need for additional details about the uniformly distributed load.
  • Nathaniel shares a link to the problem statement and considers leaving the solution in terms of the load w.
  • A participant agrees with Nathaniel's approach, suggesting to assume a parabolic shape for the cable and to solve for cable length and height in terms of w.
Participants generally agree that additional information is needed to solve the problem definitively, particularly regarding the uniformly distributed load. There is no consensus on the specific values or relationships due to the incomplete information provided.
The discussion highlights limitations related to missing assumptions about the loading conditions and the cable's weight. The relationship between tension, sag, loading, and span length remains unresolved.
NDO
The cable to be used for the suspension bridge can safely support a tension of 40 MN.
 Calculate the shortest length of the cable that can be used to construct the bridge.
 Calculate the corresponding value of h.
(Neglect the issue of safety factor).
L = 72
I have no idea
i have been trying to find any equation to find the sag or the length but i need the sag to get the length or i need the load to get the sag.
can anyone give me a point in the right direction
cheers Nathaniel
NDO: We need to know how the cable is loaded. Have you omitted some information, or a diagram? Also, are the supports at each end of the cable at the same elevation?
From your current post, it almost sounds like the cable is loaded with a uniformly-distributed load w, is of negligible self weight, and both supports are at the same elevation, right? Or wrong?
You have not yet indlcated the cable weight or the uniformly distributed load from the train load and deck. Cables hanging under their own weight form a catenary using the hyperbolic functions (which can be approximated by a parabola when the sag is much less than the span) . When cable weight can be neglected in comparison to the uniformly horizontally distributed dead and live loads, it takes on a parabolic shape. That probably doesn't help with your answer,though, until you come up with the correct relationship (equation) between Tension, Sag, loading, span length, etc., whether it's a catenary or a parabola.
NDO: With only the information you posted above, the problem has infinite solutions. You gave us only span length L, cable tension, and an unknown uniformly-distributed load w. Well, for any value you choose for cable length, s, greater than 72 m, there is a corresponding value of w that will cause exactly 40 MN of cable tension.
Therefore, I believe you may be omitting some information that we need to know to be able to solve the problem. Can you post an actual picture of the problem statement, so we can read exactly what it says?
NDO: I agree. Assume the cable has a parabolic shape and is weightless, and probably use only the first two terms of the cable length (series) formula. Solve for cable length in terms of w. Then for part (b), solve for h in terms of w. Post your answers if you want someone to try to check your math.
  • · Replies 39 ·
10K
14K
  • · Replies 31 ·
