Calc 3 Range of a function (set of points)
The discussion revolves around understanding the range of a function in the context of a calculus problem, specifically focusing on inequalities and transformations applied to them. Participants are examining the steps taken in a solution involving the manipulation of inequalities and the implications of multiplying by negative numbers.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants express confusion about the transition between steps in the solution, particularly regarding the origin of certain constants and the effects of multiplying inequalities by negative numbers. Questions arise about the treatment of inequality signs during these transformations.
The discussion is active, with participants seeking clarification on specific steps and reasoning. Some have provided insights into the manipulation of inequalities, and there appears to be a growing understanding among participants as they engage with each other's questions and responses.
Participants are working from an image that contains the original problem statement and equations, which are not fully detailed in the text. There is a noted concern about the handling of inequalities when multiplied by negative numbers, reflecting a common area of confusion in mathematical reasoning.
xtrubambinoxpr
See attached image
they are provided in the image. I see the domain is used
I can't figure out how they went from step one to step 2. where does the -81 come from and the 9 multiplied to the function in the middle. I tried to figure it out and all i got was divide everything by 9 then multiplying by 18 across to get 9 in the middle but that won't get me 81 on the eft hand side.
Thank you in advance!
xtrubambinoxpr said:
See attached image
What happens to the first batch of inequalities when you multiply everything by -9?
Well I'm pretty retarded lol
But what about the greater than or equal to signs? And why weren't they reversed? Like from elementary you learn to flip them if it's anything with a negative number.
I doubt that very much if you're taking Calc 3. Inexperienced? Almost definitely. Ill prepared? Possibly. Too stupid? Not very likely.
Look again. The inequalities were flipped, and then the whole line was flipped.
Ahhhhh I see it now! Thanks a lot! This helps a lot this section because I couldn't put the pieces together!
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 19 ·
