Calculate expectation value of entangled 2 state system?
4 replies · 3K views
ianmgull
I know that there are two eigenstates of the operator C:
|B> = (1 0) as a column vector with eigenvalue 1
|R> = (0 1) also a column vector with eigenvalue -1
My work is shown here:
If anyone could point me in the right direction, I'd greatly appreciate it. I've been stuck for hours and just can't figure out what I'm doing wrong.
thanks
Ian
on Phys.org
Use a projection operator. A projector on the red basis would look like [itex]P_R = |R\rangle\langle R|[/itex]. Then (dropping 1 and 2 subscripts, and assuming orthogonal states):
[itex] Prob_R =\frac{1}{2} (\langle B|\langle R| - \langle R|\langle B|)|R\rangle\langle R|(|B\rangle|R\rangle -|R\rangle|B\rangle )=\frac{1}{2}[/itex]
The expectation value of C is the probability that the measurement produces either 1 or -1, so the average result will be 0.
I just worked it out and that makes much more sense.
I'm still a little unclear on (conceptually) what meaning I should attribute to taking the expectation value of an operator (like above) vs a projection operator.
Thanks so much!
The eigenvalues are what can be measured in a lab; an expectation value will give you the average result that will be obtained over a large number of measurements, in this case 0. A projection operator projects the state onto a basis (red or blue) according to a probability, 1/2 here.
