Calculate Inertial tensor of 5000 points
Yuriick
I was given a sample of 5000 points from an ellipsoidal blob (in 3D) that has some orientation. Assuming that each point has equal mass, I was asked to calculate the inertia tensor of this blob, then find the principal axes to determine the orientation of this blob.
R = [itex]\frac{1}{M}[/itex][itex]\sum m_{i}r_{i}[/itex]
where M is the sum of the masses of every point
R is the center of mass
I = - [itex]\sum m_{i} [r_{i} - R][r_{i} - R][/itex]
Since all the mass for every particle is the same, the formula for center of mass becomes,
R = [itex]\frac{1}{5000}[/itex][itex]\sum r_{i}[/itex]
however I'm not sure how to find the inertial tensor since I don't know the mass of each particle.
Any help would be much appreciated, thanks!
Perhaps you do not know the mass of each particle (in your line with the CM, you seem to assume that every mass is of mass "m", therefore, M = 5000*m). Why not scale out this unknown m, adn compute I/m? I bet you know all the r_i from your initial data set, and it seems like you can compute R. Is there a more complicated thing stopping you, even in light of this simple suggestion?
