Calculate mass or number of atoms based on MBq?
  • Thread starter Thread starter beany_bot
    Atoms Mass
The discussion focuses on calculating the number of Technetium-99m (Tc-99m) atoms in a 10 MBq dose and its potential impact on the properties of an aerosol labeled with Technegas. It emphasizes the importance of specific activity, which is defined as Bq per gram, and the need for correction factors due to potential impurities and decay. The use of a dose calibrator machine in radiopharmacy is highlighted as a standard method for determining the MBq in a sample, ensuring accurate measurements for practical applications.
  • Understanding of Technetium-99m (Tc-99m) and its properties
  • Knowledge of specific activity calculations in radiochemistry
  • Familiarity with dose calibrator machines used in radiopharmacy
  • Basic principles of aerosol physics and particle size effects
  • Research the specific activity of Technetium-99m and its implications for radiolabeling
  • Learn about the operation and calibration of dose calibrator machines in radiopharmacy
  • Investigate the effects of particle size on aerosol behavior and delivery
  • Explore correction factors for impurities in radiochemical samples
This discussion is beneficial for radiopharmacists, nuclear medicine professionals, and researchers involved in the development of radiolabeled aerosols and their applications in medical imaging and therapy.
beany_bot
Trying to work out how many atoms of Technetium-99m there are in a 10 MBq dose?
Basically trying to work out if the actual weight of the Technetium-99m will affect the "flight" properties of an aerosol labeled with Technegas. Or would it be negligible?
Basically will using Technegas to radiolabel an aerosol affect it's properties due to the relatively high mass of the Technetium atoms relative to the existing dry power (e.g. lactose). Let's assume the powder is 20 micron sized particles and the Technetium will "coat" the surface.
see Wiki on "specific Activity"
https://en.wikipedia.org/wiki/Specific_activity[/URL}
If you've got some nuclide of interest, say Tc99m, then you can look up the "specific activity" for that nuclide.
This gives you Bq per gram. (Then I'll let you convert grams to atoms, as an exercise for the reader.)
But this assumes that you've got nothing but pure 100% Tc-99m in your sample.
This assumes none of the nuclide has decayed, that it's 100% Tc-99m atoms, that it's not mixed in with any Tc-99 ground-state atoms or anything else, and it assumes that there's no other atoms attached to a molecule padding out the weight. The presence of all of those factors needs to be a correction factor, when you determine Bq per gram for your real-world radiochemical material.
In radiopharmacy, with a common nuclide such as Tc99m, this is often done with a dose calibrator machine which is counting in a known geometry - just put your hot vial inside, and it will tell you how many MBq are in it.
  • · Replies 28 ·
  • · Replies 38 ·
11K
19K
