Calculate pH of Buffer CH_3COOH & CH_3COONa
To calculate the pH of the buffer solution made from 55 mL of CH3COOH and 45 mL of CH3COONa, the Henderson-Hasselbalch equation is essential. The acetic acid concentration is 0.10 M for both components, and the dilution of 10 mL of this buffer to 100 mL with deionized water must be considered. The pKa can be calculated using the formula pKa = -log(1.76 x 10^-5). After determining the concentrations post-dilution, the pH can be easily calculated. Understanding these steps will simplify the process of finding the expected pH of the buffer solution.
n77ler
Buffer solution : CH_3COOH (55 mL) + CH_3COONa (45 mL)
Ka (CH_3COOH) = 1.76 x 10^-5
Calculate the expected pH of your buffer solution after it has been dilted by making 10 mL of buffer up to 100 mL with deionized water.
Ice charts
n= c x v
c= n/v
I've calculated the pH for other additions of strong acids and strong bases but I'm not sure how to start this one. Little bit confused... Just the first step would be a great help :)
You haven't given enough information to start. You need to know something about the concentrations of acetic acid (55 mL?) and acetate (45 mL?).
Sorry, they are both 0.10 M
Review the Henderson-Hasselbach equation. Hint: pKa = -log[Ka]
Ice charts
n= c x v
c= n/v
the question is a little confusing due to the given volumes.i need help how to attempt the question.
As chemisttree already wrote: use Henderson-Hasselbalch equation. Start calculating concentrations of both acid and conjugate base. At this stage it will be simple dilution problem.
(in fact you can solve the problem without calculating these concentrations, but I guess explaining the shorter route will only confuse you more)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
