Calculate pressure inside closed container
The discussion centers on calculating the pressure inside a closed reactor with a volume of 75.36 ml containing a 5% sulfuric acid (H2SO4) mixture at a temperature of 150 °C. The participant considers using steam tables for water to determine the pressure due to the diluted nature of the mixture. The consensus suggests that while steam tables for sulfuric acid are ideal, the water tables may suffice for this specific calculation.
  • Understanding of steam tables and their application in thermodynamics
  • Basic knowledge of chemical properties of sulfuric acid
  • Familiarity with pressure calculations in closed systems
  • Experience with reactor design principles
  • Research the use of steam tables for sulfuric acid specifically
  • Learn about pressure calculation methods in closed containers
  • Investigate the effects of temperature on vapor pressure
  • Explore reactor design considerations for chemical mixtures
Chemical engineers, process designers, and students involved in reactor design and thermodynamic calculations.
Bartbol
For the design of a reactor I need to calculate the pressure inside the closed reactor.
Reactor volume = 75,36 ml
Mixture inside the reactor = 30 ml H[2]SO[4] (5%)
Temperature = 150 °C
I was thinking I will need the steam tables for water - sulfuric acid, but since it is a very diluted mixture I could just use the steam tables for water. Anyhow I hoped somebody could help me on the way of solving this problem!
Many thanks in advance!
Regards!
You thought about using tables - but have you tried to use them?
  • · Replies 21 ·
