Calculate Retarding Force of 50kg & 6kg Objects
  • Thread starter Thread starter Taidhg
    Force
The discussion revolves around calculating the retarding force experienced by two objects of different masses (50kg and 6kg) after a free fall and subsequent impact with the ground. The scenario involves concepts of gravitational potential energy (GPE) and kinetic energy (KE) as they relate to the motion of the objects.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the calculations of velocity, gravitational potential energy, and kinetic energy. There are questions about the correctness of the equations used and the implications of energy differences upon impact. Some participants suggest drawing diagrams to clarify the positions of the objects during the fall.
The discussion is ongoing, with participants providing guidance on the need for detailed calculations and questioning the assumptions made about energy conservation during the impact. There is an exploration of the role of friction and retarding forces, with some participants expressing uncertainty about the necessary information to proceed.
Participants note that the objects are initially in free fall, but after impact, they are subject to retarding forces from the ground. There is mention of energy loss during the impact, which complicates the calculations of the retarding force.
Taidhg
Member has been warned not to remove the template.
1. An object with a mass of 50kg is raised vertically 4 meters above an object of 6kg and then is allowed to fall freely onto the object into the ground. Both objects travel into the ground to a depth of 24cm without rebounding.
Calculate the retarding force causing both objects to come to rest.
KE/GPE = mgh = 0.5m v2
What have you done so far? The relevant equation that you wrote is wrong.
I've calculated the velocity upon the objects impact which is 1.476 m/s2
I also have calculated the GPE before it falls which is 1962J and the kinetic energy upon impact which is 1961.33J
I just don't see how I am meant to calculate this last question.
In all such problems, you should draw a diagram, labeling the different positions. Similarly, label the two balls as A and B. For example, the initial position , with ball A at the top of its path and ball B on the ground can be called position 1. The position just before impact is called 2, and the final position after the two balls sink and come to rest together is called 3.
Your unit for velocity is wrong.
Do you think the kinetic energy in position 2 should be different from the potential energy in position 1?
What information do you need to calculate the last part? How can you get that information?
Please show your calculations in detail.
I really don't know what information I need for the last part that's the issue. I know that the energy used in response to stop the objects will obviously be equal but I've never worked with retarding forces before.
How about friction?
gneill said:
How about friction?
I stated in the original post that the object is in free fall. The question is about a pile driver falling onto a pile but I usually ignore those details.
After the collision occurs, the objects are not in free-fall. The ground is impeding their progress. Friction.
Please show your calculation.
Why are they different?
The energy taken by the retarding force in bringing them to rest will not be equal to the initial GPE. There is energy lost in the impact itself. Have you worked with impacts before?
10K
  • · Replies 19 ·
