Calculate Shear Strength of Pin with Simple Mechanical Formula - Expert Tips
  • Thread starter Thread starter barvas11
    Mechanical
A simple formula for calculating the shear strength of a pin involves using the yield strength of the material, with the distortion energy theory suggesting Ssy = 0.58Sy. For a pin with a yield strength of 355 N/mm² and a diameter of 80 mm, the maximum shear force in single shear is calculated to be approximately 1 million N. It's crucial to tailor the formula to specific applications, considering factors like the strength of the pinned material and the potential need for additional safety measures. Proper details are essential for accurate calculations. Overall, understanding the context and specifics of the application is key to determining shear strength effectively.
barvas11
Hi Guys,
What is a simple formula for calculating a shear strength of pin taking into consideration the yield strength of the material?
Is the pin in single shear or double shear?
The formula is the easy part. It's tailoring it for your specific problem that's the tricky part.
single shear
I know ;)
You need to give us much more details.
yield strength of the pin is 355 N/mm2
pin diameter is 80mmm
What is the maximum shear the pin can take?
I'll do it for you.
Let's use the distortion energy theory: Ssy = 0.58Sy
where Sy = 355 MPa
Therefore Ssy = 206 MPa
I'm assuming you're after the shear force, since you have the yield and diameter.
So F= SSy*A
F = 206*5026mm^2 = 1e6 N
Assuming single shear. It'll be double this for double shear.
I did this quickly in my head, you should probably check my working.
That is one big pin though...
Thanks Vadar2012
I did it the same way and I checked it against shearforces for bolts I found online. It appears to be right.
Please note that you could have received a better answer more quickly if you had supplied proper information at the beginning.
With pins in shear
You also have to consider the strength of the pinned material in relation to the pin material.
If the pin is a safety or protection failure device you may need yet further considerations.
