Calculate the force on a particle from magnetic field of infinite wire
The discussion centers on calculating the magnetic force on a charged particle moving near an infinitely long wire carrying a current, denoted as "i". The magnetic field strength, "B", is derived using the formula B = (μ₀i)/(2πr). The magnitude of the force, "F", is expressed as F = (q*v*μ₀*i*sin(θ))/(2πr). The participants confirm that while the magnetic field is non-uniform, the derived equation for force at a specific radius and angle is accurate.
  • Understanding of magnetic fields and forces
  • Familiarity with the Biot-Savart Law
  • Knowledge of vector cross products
  • Basic principles of electromagnetism
  • Study the Biot-Savart Law for magnetic field calculations
  • Learn about the Lorentz force law in electromagnetism
  • Explore the concept of magnetic field lines around current-carrying wires
  • Investigate the effects of varying current on magnetic field strength
Students in physics, electrical engineers, and anyone interested in understanding the interactions between charged particles and magnetic fields.
eviljay
Problem: Determine an expression for the magnitude of the magnetic force on a charged particle moving near an infinitely long wire, carrying a current i.
  • Particle with charge q
  • Magnitude of the particles velocity = |v|
  • Magnetic field strength = B
  • Current = i
B can be calculated with:
B=\frac{μ_{0}i}{2\pi{r}}
Magnitude of force can be calculated with:
F=q*v*b*sin(θ) (Cross product of the particles velocity vector and the magnetic field vector)
I've combined these equations to come up with a single equation for the magnitude of the force on the particle:
F=\frac{q*v*μ_{0}*i*sin(θ)}{2\pi{r}}
However this final equation is the part I am not confident on. I've proceeded on the basis the the magnetic field around an infinite wire carrying current is non-uniform; that is the direction of the magnetic field is not constant, but would appreciate my working being checked!
Thanks in advance!
The magnetic field is not constant, this will change sin(θ) and r in a trajectory. But the equation for the force at a specific radius with a specific angle is correct.
Current is written with a capital I. "i" is usually the imaginary unit.
Looks good.
BTW i = √(-1) is only for physicists.
Real men (engineers) use j = √(-1) and i is very regularly used to denote current :smile:
Physics Forums > Science Education > Homework & Coursework Questions > Introductory Physics >
And mathematics as well.
Yeah, but not real men (and women)! :smile:
Thanks both! Just needed that extra pair of eyes to look at it :smile:
