Calculate the Jacobian of this function
The discussion focuses on calculating the Jacobian matrix of the function g(x) = x - f'(x)^{-1}·f(x), where f(x) maps R² to R² and has continuous first and second partial derivatives. Participants clarify that the Jacobian matrix J_f for f is defined as J_f = (∂_x f_1, ∂_y f_1; ∂_x f_2, ∂_y f_2) and that J_f is invertible. The relationship J_f^{-1}·J_f = I_2 is emphasized as crucial for deriving J_g, and participants suggest decomposing g(x) to simplify the computation of its Jacobian.
  • Understanding of Jacobian matrices in multivariable calculus
  • Familiarity with continuous partial derivatives
  • Knowledge of matrix operations, particularly inversion
  • Basic proficiency in LaTeX for mathematical notation
  • Study the properties of Jacobian matrices in multivariable functions
  • Learn about the application of the inverse function theorem in calculus
  • Explore methods for simplifying the computation of Jacobians
  • Investigate the implications of continuous partial derivatives on function behavior
Mathematics students, particularly those studying multivariable calculus, and professionals in fields requiring advanced calculus, such as physics and engineering, will benefit from this discussion.
mobe
Could you please help me with this problem?
Let f(x) = (f_1(x), f_2(x)) map R^{2} into itself where f_1, f_2 have continuous 1st/ 2nd partial derivatives in each variable. Assume that f maps origin to itself and that J_f(x)(Jacobian matrix) is an invertible 2x2 matrix for all x. Put g(x) = x - f'(x)^{-1}.f(x)
(i) Explicitly compute J_g(x) using relation J_f^{-1}. J_f = Identity matrix I_{2}
Thanks in advance!
What are f'(x)^{-1} and f'(x)^{-1}.f(x)
? I am just having trouble with the notations.
Can you give me hints?
( For some reason, I can't you tex right?)^{}
Well firstly, I don't think you've entered your question correctly. If f\in C^2(\mathbb{R}^2), \quad f:\mathbb{R}^2\rightarrow \mathbb{R}^2 then it's more likely that f(x,y) = \displaystyle \left( f_1 (x,y), f_2 (x,y) \right). If f were indeed simply a function of x, then your Jacobian matrix would be singular.
Now your Jacobian matrix for f will look like
Jf = \begin{pmatrix} \partial_x f_1 & \partial_y f_1 \\ \partial_x f_2 & \partial_y f_2 \end{pmatrix}
Then you don't need to explicitly calculate f^{-1} (x,y) [/tex] since you only need it&#039;s Jacobian matrix. <br /> <br /> Jf^{-1} = \frac{1}{\partial_x f_1 \partial_y f_2 - \partial_x f_2 \partial_y f_1} \begin{pmatrix} \partial_y f_2 &amp;amp; -\partial__y f_1 \\ -\partial_x f_2 &amp;amp; \partial_x f_1 \end{pmatrix}.<br /> <br /> Is f^\prime (x) ^{-1} \cdot f(x) the dot product? If it is then g:\mathbb{R}^2 \rightarrow \mathbb{R} \text{ and } Jg \in M_{1\times 2} (\mathbb{R} )
Thanks for the reply!
I got up to g = x - f'(x)Click to see the LaTeX code for this image.f(x) in term of J_f and J_f^-1. I want to compute J_g but continue doing the same thing ( taking partial derivatives) would make J_g look awfully ugly. I am curious if there is another way to get J_g? I got a hint: (J_f)^(-1).J_f = Identity matrix I_2 but I do not know how to use it.
Jf = \begin{pmatrix} \partial_x f_1 &amp; \partial_y f_1 \\ \partial_x f_2 &amp; \partial_y f_2 \end{pmatrix}
<br /> <br /> Yes, I believe that it is the dot product.
Just to move it down here.
I'm pretty sure you should be able to decompose g(x) over it's sums. That is
g(x) &amp;=&amp; x - \frac{df^{-1}}{dx} f(x) \\
=x-f_1 \frac{df_1^{-1}}{dx} - f_2 \frac{df_2^{-1}}{dx}
Now I'm not 100% sure about this, but I think that in your case, since g:\mathbb{R}^2 \rightarrow \mathbb{R} \text{ and } Jg \in M_{1\times 2} (\mathbb{R} )
That you can say J(f+g) = J(f) + J(g) \text{ and } J(fg) = (Jf)g+f(Jg) [/tex] and just substitute f and g with the appropriate functions. Play around with it and see what happens. <br /> <br /> Edit: I&#039;m not sure if this will hold in higher dimensions, but I think it holds in M_{1\times 2} (\mathbb{R} ) since the Jacobian just ends up being the gradient of each scalar function. Not sure if that helps you at all.
I think <br /> g:\mathbb{R}^2 \rightarrow \mathbb{R} \text{ and } Jg \in M_{1\times 2} (\mathbb{R} ) <br /> is right. I will use your suggestion and see where it gets me. Thanks! ( I may post more question).
