Calculating the Limit of (1 + 2^x)^(2^(-x))
  • Thread starter Thread starter LCSphysicist
    Limit
The limit of (1 + 2^x)^(2^(-x)) as x approaches infinity is discussed, concluding that it approaches one. The confusion arises from equating this limit with Euler's number, leading to a misunderstanding about the behavior of the variable a when it is unbounded. A key point is that if a approaches infinity, the limit does not align with the definition of Euler's number. The discussion emphasizes the necessity for the terms within the parentheses to tend toward one rather than infinity for the limit to hold true. Clarification on these points resolves the initial misconceptions about the limit's behavior.
LCSphysicist
(1 + a^x)^(a^(-x))
(1 + a^x)^(a^(-x))
Let's assume a, say, two.
the limit of it, with x tending to infinity,
is one, but i was thinking...
Calling 2^x by a, we have that when x tend to infinity, so do a, So:
that is euler number no? Contradictory... where am i wrong?
LCSphysicist said:
one
That's what I got. The way I usually deal with limits of this form is to express it as a function of the exponential function and the natural logarithm, then use l'Hopital's rule on the power.
Yes but, what is wrong in the second case?
I think that the problem is that ##a## is not bounded, and it would not be the same as the limit for Euler's number if you tried to put it that way. For example, if you let ##a=\frac{1}{n^2}##, then as ##a\rightarrow \infty##, ##n^2\rightarrow 0^+##. Then your second limit becomes:
##\lim_{a \rightarrow \infty}(1+a)^{\frac{1}{a}}=\lim_{n^2\rightarrow 0}(1+\frac{1}{n^2})^{n^2}\neq e##
Maybe if you switched around the negative signs in the equation in the Relevant Equations part of your post, it would be some function of Euler's number.
Likes LCSphysicist
Euler's number is ##\lim (1+\frac{1}{n})^n ## as ##n\to \infty## or equivalently ##\lim (1+n)^{\frac{1}{n}}## as ##n\to 0##.
BUT you have ##\lim (1+n)^{\frac{1}{n}}## as ##n\to \infty##
Likes SammyS, FactChecker and LCSphysicist
Oh so i was wrong to think that the third therm was too equivalent.
I really messed me up, the terms between the parentheses need to tend to one, not to infinity... thank you both guys
Likes Delta2
  • · Replies 25 ·
  • · Replies 17 ·
