Calculate the magnitude of the angular momentum of the earth
The discussion focuses on calculating the angular momentum of the Earth as a particle orbiting the Sun. The mass of the Earth is given as 5.97 x 1024 kg, with an orbital radius of 1.50 x 1011 m and a speed of 2.98 x 104 m/s. The initial attempt incorrectly calculated the moment of inertia using the radius of the orbit instead of treating the Earth as a point mass. The correct angular momentum is calculated using the formula L = mvr, resulting in L = 1.069227 x 1040 kg*m2/s.
  • Understanding of angular momentum concepts
  • Familiarity with the formula L = Iω
  • Knowledge of circular motion and orbital mechanics
  • Basic physics of solid spheres and point masses
  • Study the concept of angular momentum in orbital mechanics
  • Learn about the differences between point mass and solid body calculations
  • Explore the implications of moment of inertia in different shapes
  • Investigate the effects of mass and radius on angular momentum
Students in physics, particularly those studying mechanics and orbital dynamics, as well as educators looking for examples of angular momentum calculations.
Chandasouk
Calculate the magnitude of the angular momentum of the Earth considered as a particle orbiting the sun. The mass of the Earth is 5.97 x 10^24kg . Treat it as moving in a circular orbit of radius 1.50 x 10^11m at a speed of 2.98 x 10^4m/s
I first try to find the moment of Inertia of the earth, I. I treated the Earth as a solid sphere so
I=2/5(5.97 x 10^24kg)(1.50 x 10^11m)^2
= 5.373 x 10^46 kgm^2
I then found the angular velocity of the Earth by
V=\omegar
2.98 x 10^4m/s/1.50 x 10^11m=\omega
\omega=0.000000199 rad/sec
Then
L=I\omega
L=(5.373 x 10^46 kgm^2)(0.000000199 rad/sec)
L=1.069227 x 10^40 kg*m^2/s ?
I first try to find the moment of inertia of the earth, I. I treated the Earth as a solid sphere so
It is wrong. Treat the Earth as the particle
And in the above calculation you have substituted for R the radius of the orbit, not the radius of the earth.
The problem asks the orbital angular momentum of the earth, as a point mass. The moment of inertia with respect to the centre of mass should be neglected.
By the way, you really think that the radius of Earth is 1.50 x 10^11 m ?
ehild
  • · Replies 17 ·
  • · Replies 19 ·
16K
