Vladimir_Kitanov
- 44
- 14
Misplaced Homework Thread
Why force at D need to be parallel to force at E and F?
Force at D does not need to be, it happens to be parallel as a consequence of the coincidential direction of the only other forces acting on that member DEF.Vladimir_Kitanov said:Why force at D need to be parallel to force at E and F?
How ever I tried I did not managed to solve it.Lnewqban said:I believe so.
Have you done any solution work that we could see?
I brake that in pieces but always get 2 unknowns and 1 equation.Lnewqban said:I believe so.
I can't send picture now it say that I have low memoryLnewqban said:Could you please show us what you have done so far?
Okay thanksLnewqban said:Thank you!
Hard to see, but I will try a little later.
Still can't do that.Lnewqban said:Sorry for later than promised response.
The two horizontal members, AC and DF are not working purely under compression or tension, like it would happen in a truss.
This is an armature, in which some members are supporting bending and shear loads.
That is the case for those two horizontal members.
You could try estimating those loads by calculating moments and forces also about the intermediate points B and E respectively.
The reactions at those points, aligned with the 3-4-5 triangles, would be the asked axial loads of members CF and BE (both under pure axial loads, no bending or shear).
The rest would be to estimate the stresses that those axial loads impose on the 2x4 cross sections.
No, sorry, I have had no time to properly do it.Vladimir_Kitanov said:Did you solve it?
No.Lnewqban said:Do you need to do that to solve the original question about maximum internal loads of members BE and CF?
I tried to solve it without assuming that forces are parallel, but failed.Lnewqban said:I see, but why?
Aren’t you only trying to solve the problem as described in the original post?
Sorry, I am confused.
I already knowed how to solve those problems but that confused me.Lnewqban said:OK, let’s start from scratch.
In general terms, what have you learned about solving structures so far?
