Calculate the total momentum after the collision
The discussion focuses on calculating the total momentum after a collision involving two objects with equal masses of 0.55 kg. The initial velocities are 0.79 m/s East for the first object and 0 m/s for the second. After the collision, the velocities change to 0.366 m/s at 51 degrees North of East for the first object and 0.61 m/s at 21 degrees South of East for the second. The correct approach involves using vector addition to determine the momentum components in both the x and y directions, ultimately leading to the total momentum calculation.
  • Understanding of vector addition in physics
  • Knowledge of momentum as a vector quantity
  • Familiarity with trigonometric functions for resolving vectors
  • Basic principles of collisions in physics
  • Learn how to resolve vectors into components using trigonometric functions
  • Study the conservation of momentum in elastic and inelastic collisions
  • Explore graphical methods for vector addition
  • Practice problems involving momentum calculations in two dimensions
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators looking for examples of collision problems.
daewoo
Hey guys, I'm stuck on this momentum question, i think I have an idea but have no way in proving it.
(here is part c to the question)
Calculate the total momentum after the collision. Compare this value to the total momentum before the collision. If these values differ, some likely causes of error were?
Mass(1)= 0.55kg, Mass(2)=0.55Kg, V1 =(0.79m/s East), V2= (0m/s)
V1 prime = (0.366m/s, 51 degrees N of E), and V2 Prime = (0.61m/s, 21 degrees S of E)
the prime means the change in velocity after a "collision" i first thought of using (m1v1 + m2v2) =(m1v1(prime) + m2v2(prime)) but the degrees and direction are confusing me, Unless i should use vector addition to add the angles.
Any ideas?
Momentum is a vector quantity, so yes, Vector addition.
thought so, but how would I start it off? would i find the momentums of the primes then draw it? finding the x and y componets?
Yes.
Info
|\vec{v}_{1}|= 0.366 m/s
|\vec{v}_{2}|= 0.61 m/s
\theta_{1} = 51^{o}
\theta_{2} = 21^{o}
\vec{v}_{1} = |\vec{v}_{1}| \cos \theta_{1} \vec{i} + |\vec{v}_{1}| \sin \theta_{1} \vec{j}
\vec{v}_{2} = |\vec{v}_{2}| \cos \theta_{2} \vec{i} - |\vec{v}_{2}| \sin \theta_{2} \vec{j}
\vec{v}_{R} = \vec{v}_{1} + \vec{v}_{2}
\vec{p}_{total} = m \vec{v}_{R}
  • · Replies 16 ·
