Calculating amount of precipitate that will form
  • Thread starter Thread starter ultimateguy
    Form
The discussion focuses on calculating the amount of precipitate, specifically zinc sulfide (ZnS), formed when mixing 20.0 mL of 0.150 M Zn(NO3)2 with 20.0 mL of 1.00 x 10^-4 M Na2S. The solubility product constant (Ksp) for ZnS is 1.6 x 10^-24 M^2. The correct calculation reveals that 4.85 mg of ZnS precipitate forms, determined by identifying the limiting reagent and adjusting concentrations based on the final volume of the solution.
  • Understanding of stoichiometry in chemical reactions
  • Knowledge of solubility product constants (Ksp)
  • Ability to calculate molarity and concentration changes
  • Familiarity with the concept of limiting reagents in chemical reactions
  • Study the calculation of precipitate formation in reactions involving Ksp
  • Learn about the principles of limiting reagents in chemical equations
  • Explore the effects of concentration changes on equilibrium in chemical reactions
  • Review stoichiometric calculations involving molar mass and mass conversions
Chemistry students, laboratory technicians, and educators seeking to understand precipitation reactions and stoichiometric calculations in solution chemistry.
ultimateguy
20,0ml of 0,150M Zn(NO3)2 are mixed with 20,0ml of 1,00 x10^-4
M Na2S. Calculate the amount of milligrams of
ZnS (s) that will precipitate. (Ksp = 1,6 x10^-24
M^2 )
a) 2,68mg
b) 0,347mg
c) 4,85mg
d) 0,194mg
There are zero examples in my textbook or notes that deal with calculating the amount of precipitate that will form. Can someone help?
Does the problem description give a large excess of one of the reactants? What can this do the the equilibrium of the reaction? Is the product very very insoluble based on the size of the solubility product constant?
1) Yes,
2) Makes it small
3) Yes
I think I got it. I calculated 4.85mg by finding the new concentrations with the new volume and then using the smaller concentration to find the amount in grams.
Show your calculations. Remember you only have a 25% chance if you quess the answer.
[Zn] = (0.15M x 0.02L)/(0.04L) = 0.075M
= (1x10^-4M x 0.02L)/(0.04L) = 5 x 10^-5M
Then multiplying 5 x 10^-5M by molar mass of ZnS and finding the amount of grams in 0.04L I got 4.85mg.
Try again. Why are you multiplying a concentration by a formula wt?
Units would be grams/liter...
If you have already decided that one of the reagents is limiting and that the concentration of ZnS in solution is insignificant (something times 10^-23 mol/L, I believe), then the amount of precipitate will essentially be equal to the number of moles of the limiting reagent.
Isn't that what I did? S is limiting, so I took the mass of that, which is 4.85mg.
moles S = (1 X 10^-4 mol/L)*(0.02L) = 2 X 10^-6 mol S
mass of S (g) = (2 X 10^-6 mol S)*(FW ZnS)
mass of ZnS (mg) = 1000 * mass ZnS (g)
You found the amount in grams in 0.02 L. The final volume is 0.04 L.
Ah I see it now. Thanks. (Now how about that other thread? :P)
12K
23K
22K
