Calculating Angle Between Cube Ribs
  • Thread starter Thread starter sky08
    Angle Cube
The discussion revolves around calculating the angle between two ribs of a cube, specifically from the vertices (referred to as "heads") to the center of the cube. The original poster attempts to apply the cosine law in a three-dimensional context to find this angle.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the definitions of "ribs" and "heads," with some suggesting they refer to diagonals and vertices, respectively. There are attempts to apply the cosine law and considerations of symmetry in the geometry of the cube.
Participants are actively engaging with the problem, with some providing insights into the relationship between angles and sides in the cube. There is a recognition of symmetry that may simplify the calculations, and guidance is offered regarding the application of the cosine law.
There is some confusion regarding terminology, particularly the terms "ribs" and "heads," which may affect the understanding of the problem setup. Additionally, the original poster mentions an attachment that presumably contains a visual representation of the problem.
sky08
hello , How are you all?
look at this question
what the magnitude of the angle that between two ribs from the heads of the cube to its center ?
I attempted by using cosine law [look at the pecture in attachment]
but, Hwo to apply this law on the cube (3D)?
any one help me >>and thank you anyway
I am afraid that I don't understand what you mean by "ribs" or "heads" of a cube. Are the "ribs" diagonals and the "heads" vertices? In that case, the angle between two diagonals is a right angle. You don't need the cosine law to see that.
yes ,,
look at attachment the picture is clear that explanation
I calculat it by using simple way but How to use cosine law to giveangle theta in pecture
an thanks Mr.HallsofIvy
Hmm in the drawing is theta the same as angle BOA? Well either way it's BOA or half of BOA due to symmetry so you can find BOA easily and divide if you have to.
Angle BOA has two [tex]\frac{\sqrt{3}r}{2}[/tex] sides that make up Angle BOA. The law of cosines tells us that [tex](AB)^2 = (OA)^2 + (OB)^2 + 2(OA)(OB)cos(Angle BOA)[/tex]. Then just solve for Angle BOA.
Although really you shouldn't need the law of cosines.
sorry , my explanation not clearly anyway
now I understand
used cosine law directly and I don't need analysis all angles because I can find it from symmetry considerations .
thank you very much
Err, the formula is [tex](AB)^2 = (OA)^2 + (OB)^2 - 2(OA)(OB)cos(Angle BOA)[/tex].
thanks Mr. BoundByAxioms for your correcting :>
I hope the best for all
  • · Replies 35 ·
