Calculating Bullet Trajectory Distance at 30° Angle
  • Thread starter Thread starter Robert Alan
    Bullet Trajectory
14 replies · 4K views · last reply
Robert Alan
A bullet is shot at initial velocity of 600m/s at an angle of 30 degrees. How far will it travel before landing? (Assume no air resistance)
v=600m/s
a=9.8m/s^2
t=?
distance=?
x=x0+v0t+1/2at^2
I'm stuck on this one. I can calculate its distance shot straight up, or from a level surface and I can calculate its time shot straight up or from a level surface. The angle is throwing me off. Does this have something to do with a cosine of 30 degrees?
Yep :wink: To start, split the motion into horizontal and vertical components.
Okay. The horizontal component at 30 degrees is = 600cos30? And the vertical component is 600sin30? What now?
Use the vertical components to find the total time taken for the motion
[tex]x=x_0 + v_0t - \frac{1}{2}gt^2[/tex]
Okay. So I get x=300t-0.5t^2 (For this problem we assume g=10m/s^2). At 30 seconds it will attain a height of 4500. I got this by putting y=300t-5t^2 in my calculator and finding the maximum. Now I know how high it goes and how long it is in the air. Now what do I do to find the range of it?
Use the horizontal velocity to find out how far the bullet travels during the time it is in the air.
When the bullet hits the ground, the displacement is zero, so y=0 and find t.
Oh snap! So I got 30sec at the max time, double it because the rise and fall are symmetrical. That gives 60sec. Then using x=vt or x=600cos30(60) I got 31176.91 meters! Is that right?
Thanks so much for the help! I'm starting to see things now in terms of vectors. Very interesting! :)
I am pretty bad at physics so I am trying to follow the problem but I get stuck here. I thought that v0=600m/s. How come you wrote 300? Is it because v0 is m/s while gravity is m/s2?
Vertically for x=x0 +v0t-(1/2)gt2
v0 is the vertical component of the initial velocity.
So v0 = 600sin(30) for the vertical component and 600cos(30) for the horizontal component?
yes.
