Calculating Charge Entering an Element: Q=6.667 C
  • Thread starter Thread starter Wolverine31
    Charge Element
The discussion revolves around calculating the charge entering an element with a given current function. The current is constant at 2 A for 01 seconds. The participant initially struggled with using the integral method but later realized the correct approach. They calculated the charge for the first interval as 2 C and integrated for the second interval, ultimately confirming the total charge as 6.667 C. The participant expressed gratitude for the clarification that helped them arrive at the solution independently.
Wolverine31
The current flowing through an element is i = 2 A for 0<t<1 and i = 2t^2 A for t>1
Calculate the charge entering the element from t=0s to t=2s.
Answer: 6.667 C.
I used Q=t1∫t2 i dt
I tried to solve using integral method. but how to proceed here as for 0<t<1 i is constant and i am stuck. Are there any other methods.
I think this is a very basic problem but still I cannot do it because i am a newbie and may be to need work harder. Sorry for consuming your time.
If the current is constant over a given time interval, how much charge is accumulated? Remember, 1 ampere = 1 coulomb / second.
Why did you chose the integral method to solve this problem if you cannot integrate a constant function?
Thank you for pointing out. I made this post in hurry without thinking. And now i got the answer myself.
for 0s to 1s i = 2A so q = 2C
for 1s to 2 s i calculated by integrating i wrt dt between 1s to 2s
and added two values and the answer is correct.
