Calculating Cn for general wave solutionbasic Quantum physics
The discussion revolves around calculating the normalization constant Cn for a wave function in quantum mechanics, specifically for problem 2.5 in Griffiths' text. The wave function is expressed as a combination of the first two stationary states of an infinite square well, leading to the equation Cn = sqrt(2/a) * int(sin(n*pi*x/a) * Si(x,0) dx, 0, a). The user encounters difficulties simplifying the integral, resulting in a term sin(n*pi) that equals zero for integer n, causing confusion about the absence of Cn. Suggestions are made to utilize the orthogonality of the wave functions to simplify calculations, and the importance of correctly expressing the time-dependent solution is emphasized. The user expresses a mix of frustration and newfound clarity, indicating progress in understanding the problem.
knightpraetor
This is for problem 2.5 in griffiths text
basically they say that the wave function as Capital Si (x,0) = A (si1(x) + si2(x), where si1 and si2 are equal to the first two stationary states of an infinite square well.
i need to get Cn..my normalization constant is sqrt(2)/2..and I'm using the same formula that they use to get it in example 2.2
so I use equation 2.37
Cn = sqrt (2/a) * int (sin (n*pi*x/a) * Si (x,0) dx, 0, a)
into this equation i insert (Sqrt(2)/2) * si (x,0) which was given in the initial question as
si (x,0) = A(si1(x) + si2(x)) where si1 and si2 are the solutions to the first two stationary states of the infinite square well
these should be si1 = sqrt (2/a) * sin (pi*x/a) and
si2 = sqrt (2/a) * sin (2*pi*x/a)
anyways, I'm wondering if I"m doing it write up to here..because in the next step I'm not sure how to simplify the equation to integrate easily so i just plug it into the calculator.
this gives me a function of n as is used in example 2.2 to get Cn...however, my equation has sin n*pi multiplied by the rest of the equation..the problem is that sin n*pi is always equal to zero for any integer n. Therefore i have no Cn.
Obviously I'm doing something major wrong. So i was hoping to get some help on this. I've solved problem 36 ok since it doesn't require much.
2.6 i haven't really tried yet since squaring the initial wave function looks like a beast since it looks like a pain to square (assuming you turn e^itheta into cos theta + isin theta), though i will get to it soon hoepfully..
2.37 i also tried though..and normalizing it was ok (sqrt(16/5)), but i again was unable to get Cn..my calculator when giving the integral solution again leaves me with sin npi as a major factor..so i wonder if I'm plugging things in wrong.
Anyways, getting Cn is a major factor in these problems so i could really use some help:\
What do you know about eigenstates of the infinite square well? In particular, there is a nice property that makes this problem trivial. Try writing the product of wave function out, as
\Psi^{\ast}\Psi = (\psi_1 +\psi_2)^{\ast}(\psi_1+\psi_2)
You should find this simplifies the calculation since the wave functions are orthogonal, which is what I'm referring to above. Another way to write this (though you probably haven't seen this yet) is in Dirac notation.
\langle \Psi \mid \Psi \rangle = ( \langle 1 \mid + \langle 2 \mid)( \mid 1 \rangle + \mid 2 \rangle )
where the bra's and ket's denoted with 1 and 2 are the corresponding stationary states of the infinite square well. Using this notation the problem is very easy to solve.
my teacher told me that psi(x, 0) is fine with A = 1/sqrt(2)
what is then needed is to write the time-dependent solution
Psi(x, t) as A ( psi1(x) exp(-iE1 t/ hbar) + psi2(x) exp(-i E2 t /hbar) )
using trigonometric identities you can then work out the
probability density from the |Psi(x,t)|^2 and see how it oscillates with
time.
the integrals involved in c then only require trigonometric identities.
however, this still doesn't tell me why i couldn't derive psi (x, t) from using the formula to get Cn.
anyways, between your hint and the teachers i don't think doing the problem will be difficult now, though I'm still confused why what i was trying didn't work
  • · Replies 26 ·
