Calculating Compression of Aquarium Support Posts
9 replies · 8K views · last reply
houseguest
A large 3.00×10^4 L aquarium is supported by four wood posts (Douglas fir) at the corners. Each post has a square 3.80 cm x 3.80 cm cross section and is 80.0 cm tall.
By how much is each post compressed by the weight of the aquarium?
deltaL = F*L_0/(Y*A)
Y (for Douglas fir) = 1 * 10^10 N/m^2
This seems very straight forward, I just need to determine F.
F= ma = m(aquarium)g
but, what is the mass of a 3.00×10^4 L aquarium?
once I determine that, I figure it'll just be:
deltaL = ( m * 9.8 * .8)/(.144 * 10^10) meters
=> 5.44*10^10*m meters
How do I find m ??
Thanks for the help!
Since nothing else is given, consider the significant portion of the weight of the aquarium to be due to just water.
So I took the mass of water to be 1Kg per liter.
So the m = 3 * 10^4
Then the equation comes out as:
deltaL = ( 3 * 10^4 * 9.8 * .8)/(.144 * 10^10) meters
= 1.63 * 10^-4 m
But I am told this is the incorrect answer.
Any help?
Thanks!
What's the total area on which the weight acts, in m2?
4*.144 = .576 m^2
but, isn't it asking the deltaL for an individual post?
I thought that I might have to divide the force by 4, but that answer was also incorrect.
Thanks
Isn't it 0.0144 m2? Also, it's the pressure (stress) that causes the strain; you need to find the pressure on a single leg before you can calculate the strain. The way you originally had it, the compression distance was independent of the number of legs.
EDIT: Right, 0.00144 m2
Hang on, I see the mistake I made earlier: 3.8 cm x 3.8 cm = .038m x .038m = .00144 m^2 (thanks btw), but wouldn't then total area then be 4 * .00144 = .00576 m^2 ?
Then the pressure would be 3 * 10^4 * 9.8 / .00576.
Then plug in that pressure for F in
Is that right?
Although, it retrospect this can't be right since
deltaL = ( (3 * 10^4 * 9.8) / .00576 * .8) / (.00144 * 10^10) meters
= 2.84 m
and that is way to large to be realistic
oh yeah, duh.
Thank you so much for your help! Seriously.
