Calculating current in series circuit
6 replies · 12K views
tweety1234
can anyone please guide me on how to do question 3b? I don't seem to get the right answer. how do i calculate the voltage when the switch is closed if i don't know what the current is?
btw the right answer is 5.77 volts
v=IR?
Doc Al said:
You're given all the information needed to calculate the current.
okay so would it be like this ;
6/ 10 = 0.6 Amps
but can this value be used for the calculation when the switch is closed?
6/ 10 = 0.6 Amps
No. What's the total resistance in the circuit?
oh right, but i thought you don't include the internal resistance of the battery if the switch is open ?
6/10.4 = 0.577
0.577 x 0.4 = 0.23 volts
? is this correct?
oh i got it now , was suppose to multiply by 10 instead of 0.4
thanks for the help
This problem asks for the voltmeter reading when the switched is closed.
6/10.4 = 0.577
That's the current.
0577 x 0.4 = 0.23 volts
That's the voltage drop due to the internal resistance. But what's the full voltage reading across the battery terminals? (Does that 0.23 volts add or subtract from the battery's emf?)
