Calculating Decay Constant and Amount of Thorium Plated
The discussion revolves around calculating the decay constant and the amount of thorium isotope Th-228 that has been electroplated onto a copper sheet. The problem involves concepts from radioactive decay and requires understanding the relationship between decay rates and the amount of substance present.
  • Participants explore the calculation of the decay constant using the half-life of Th-228 and discuss the implications of unit conversions. There are attempts to relate the decay rate to the initial amount of thorium and questions about the formulas provided in the original post.
Some participants have provided calculations for the decay constant and raised questions about the relationship between decay rate and the amount of substance. There is ongoing exploration of the correct approach to part B of the problem, with hints and suggestions being offered regarding the interpretation of the formulas and the meaning of the variables involved.
Participants note the importance of using consistent units when performing calculations, as well as the need to clarify the time variable in the context of the problem statement. There is an acknowledgment of the potential missing information that could aid in solving the second part of the question.
P1nkButt3rflys
A small quantity of the thorium isotope Th(A=228, Z=90) (half-life 1.913 y) is prepared and electroplated onto a thick sheet of copper and overcoated with a thin film of gas-tight polymer. The plating and coating are both thin enough so that none of the alpha particles resulting from the decay are absorbed, and all that exit on the film side of the copper sheet are counted. Immediately after preparation, the counter registers 7340 alpha particles per second.
A)What is the decay constant of Th(A=228, Z=90)?
B)How much thorium has been electroplated onto the copper?
At=Ao*e^[-λ*t]
λ=0.693/T
A)
T=1.913y
λ=(0.693/1.913)
λ= 0.181 y^-1
This is incorrect.
Any guidance or hints would be appreciated!
Cannot see your reasoning.
i.e. what proportion of the alphas emitted are counted?
You must also be using the correct units. The half-life of Th-228 is measured in years and you have an alpha count in particles per second.
I got the first part A)
T=1.913y = 6.037e7 sec
λ=(0.693/6.037e7)
λ=1.15e-8 s^-1
but I have no idea where to start with part b. Any suggestions?
How is the decay rate related to the amount of substance present?
I'm not sure. I feel like I'm missing a formula
You listed two formulas in post #1 and used only one of them.
I was thinking:
At=Ao*e^[-λ*t]
Ao=7340 particles/sec
λ=1.15e-8 s^-1
But that leaves me with two unknowns.
I'm assuming I need to find At, to relate it to the amount electroplated onto the copper, but don't have t.
Still stuck :(
When you use formulas you have to realize what they are for, what they mean.
I was thinking:
At=Ao*e^[-λ*t]
λ=1.15e-8 s^-1
You mean you don't know t and A(t)?
Consider: the problem statement says "immediately after preparation".
What time is that?
So you reckon A(t) is the decay rate at time t?
In which case you need to relate A0 to the initial number of particles present.
Hint: the decay rate is R=-dN/dt and is directly proportional to the number of particles present.
This equation may be helpful for your question:
[itex]R = \frac{0.693N}{t1/2}[/itex]
R = activity, rate of decay
N = number of particles
t1/2 = half-life
