Calculating Electric Field of a Metal Sphere
The discussion revolves around calculating the electric field of a metal sphere with a specified radius and charge. Participants are exploring the electric field both just outside and just inside the sphere, focusing on both magnitude and direction.
  • Participants discuss the use of the equation for the electric field of a point charge and question the implications of the direction of the electric field. There is also a discussion about the electric field inside the sphere being zero and what that means for direction.
Some participants have provided hints and clarifications regarding the direction of the electric field based on the charge's sign. There is an ongoing exploration of the relationship between magnitude and direction, particularly in the context of the electric field inside and outside the sphere.
Participants are working under the assumption that the electric field inside a conductor is zero and are questioning the implications of this for their calculations. There is also mention of a related problem involving a different sphere and the need to determine the charge based on the electric field provided.
chukie
A metal sphere of radius R = 10 cm carries a total charge Q = 0.4 μC.
A. What is the magnitude of the electric field just outside the sphere, and in which direction is it pointing?
B. What is the magnitude and direction of the electric field just inside the sphere?
I have already found the magnitude of the electric field for each, but I am not sure about the direction.
Let's start with case A. How did you determine the magnitude? (Your method should also help you determine the direction).
For case B, the fact that you are attempting to determine the direction of the electric field tells me you have calculated it's magnitude incorrectly.
I used the equation E=q/(4pi*e*r^2)
That is the electric field for a point charge q, so in what direction does the electric field of a point charge point?
Outwards, since the charge is positive?
Btw do you mean that the equation I used is wrong?
Nope your equation is quite correct, I was simply giving you a hint.
Radially outwards from the centre of the sphere, correct :approve:.
Okay thanks! For B then I know that the field is 0. Does this mean there is no direction?
Correct again.
Thanks for your help! =)
A pleasure :smile:
im doing a question similar to this, except i need to find the charge on the ball. What does the "e" stand for in your equation?
that's the electric constant.
ohh ok. so, the question is:
The field just outside a 3.61 cm radius metal ball is 2.86×102N/C and points toward the ball. What charge resides on the ball?
my equation should look like:
286(4pi)(0.0361^2)(8.85E-12) = q
right?
right?
yah that should be right. check the sign of ur charge though.
yup. the charge was neg since the field pointed toward the center of the ball. Thanks!
No prob =)
