Calculating Expected Value: A Multiple Choice Quiz Question
8 replies · 2K views
ParisSpart
A question on a multiple choice test has 6 answers which just one is right and the other wrong.
If the amount of the correct answer is 10 points how many points should be substracted for a wrong answer so if nobody answers randomly choosing one of the 6 answers get, on average, 0 points?
I am trying to find the expected value like this : E(X)=10*P(X=10)+0*P(X=0) but the quiz doesn't take it correct where i am wrong?
That is the expected value if wrong answers do not give negative points.
The answer to the problem is not an expectation value, but the amount of negative points the wrong answers should get.
and how i can fo this?
What is "fo"?
Use some variable for the amount of negative points, and modify your formula for the expectation value accordingly. What do you know about this expectation value (given in the problem statement)?
i will not use expected value?
mfb said:
What is "fo"?
According to the Texas Department of Education Trilingual English/Spanish/Ebonics Program, "two 'n' dos be fo".
You want the expected number of points for a response to be zero:
If you answer correctly , you get 10 points, like you said. If ( I'm assumming) you are
answering randomly, what is your probability of guessing correctly? What is your
probability of guessing incorrectly , if you guess at random?
You have the right set up, just follow-up on it.
If the amount of the correct answer is 10 points how many points should be substracted for a wrong answer so if nobody answers randomly choosing one of the 6 answers get, on average, 0 points?I am trying to find the expected value like this : E(X)=10*P(X=10)+0*P(X=0) but the quiz doesn't take it correct where i am wrong?
This is unacceptable for homework, you've done this repeatedly. Going forward, you must use the homework template or your posts will be deleted.
LOL !
I think that be f0 .
