Calculating Force Between Parallel Wires
The discussion revolves around calculating the force per meter between two parallel wires carrying different currents, specifically focusing on a scenario where one wire carries 2.69 A and the other 4.33 A, separated by a distance of 32.7 cm.
  • Exploratory, Assumption checking
  • Participants are attempting to identify relevant equations and concepts related to the force exerted by parallel current-carrying wires. Some express uncertainty about the necessary information to proceed with the calculation.
The discussion is ongoing, with participants seeking clarification on the principles involved and the equations that may apply to the problem. There is an indication of collaborative exploration, as some participants offer to help others understand the context better.
There appears to be a lack of specific equations or detailed notes referenced in the initial posts, which may be impacting the participants' ability to engage fully with the problem.
waleye262
Two long, straight wires are separated by a distance of 32.7 cm. One wire carries a current of 2.69 A, the other carries a current of 4.33 A.
Find the force per meter exerted on the 2.69 A wire.
waleye262 said:
Knowing this will help you.
waleye262 said:
Seeing this will enable us to aid you in the question.
knowing this would help me too but i don't!
What do your notes say about force exerted by parallel current carrying wires?
