Calculating forces in an object that is leaning
  • Thread starter Thread starter Whitebread1
    Forces
The discussion centers on calculating the forces acting on a ladder leaning against a frictionless wall while a man climbs it. Participants emphasize the importance of drawing a free body diagram to visualize the forces, including weight, normal forces, and friction. They discuss how to set up force balance equations in both the X and Y directions, considering the ladder's angle and the effects of torque. The conversation highlights the need to account for all forces at the points of contact and to equate torques to find the maximum height the man can climb before the ladder slips. Overall, the focus is on applying physics principles to solve the problem effectively.
Whitebread1
A question came up in physics class that I'm curious about.
The question involved a ladder leaning against a frictionless horrizontal surface with a man climbing up it. The ground the ladder was resting on had a friction coefficient and the angle of the lean of the ladder was given. The question asked which point on the ladder was the highest the man could climb before the ladder would slide out from under him. Now, my question to you is this:
How does one determind the the components of the forces caused by the weight of a leaning object? The weight vector of an oject always points downard, but an object that is leaning or falling has forces acting upon it in both the X and Y direction, how do I determine these?
Draw a free body diagram.
I did so, but I am still a little confused.
The Weight vectors point straight down, and any normal force from the ground must point straight up because the ground is assumed to be perfectly flat. Eventhough the ladder is leaning, the weight vectors and the normal force completely cancel each other?
I am skeptical that this is the case because some force must be canceled by the force that the horrizontal wall is exerting on the ladder. Is the the firction betweent eh base of the ladder and the ground?
You should be able to determine that from your free body diagram. You know the answer to this yourself.
Please draw one and put it on image shack.
Draw an image, and post some force balance equations. I'm not going to 'give' you the answer, you're going to give it to me.
cyrusabdollahi said:
I know the answer, but I am not going to tell you. You should be able to determine that from your free body diagram. You know the answer to this yourself.
I would love to, but I am lacking a scanner at the moment. I'm just going to treat the points of contact between the ladder and the wall/floor as pivots and mess with torques and see what happens. Even if I'm dead wrong, it s fun to screw around with physics.
No, you can use MS paint and upload it on www.imageshack.com and put the link to the picture here.
And start writing down equations.
If you know how to use word, you can make the picture very nice very fast using the autoshapes, it will take you 5 mins.
Alright, I will try to keep it neat
OOps, I left friction out, hold on
You should assume forces in both the x and y directions at both edges of the ladder. You need to fix your picture.
Alright, it has been fixed
Ok, will that suffice?
What about the other wall?
If I draw cooridnate axis with the X axis parallel to the ladder, cna we assume that it holds true for both ends of the ladder?
Just to make sure I'm not confused as to what you are asking of me. You want to orient the coordinate axis in such a was so that the components of the forces acting on the ladder act in the X and Y directions, correct?
All I said was your are missing a force on the other end of the ladder. Where is the y component of force?
But I do not understand how I am missing a force. The only force the horizontal wall cna exert is the normal force because that horrizontal wall is frictionless, isn't that right? I appologize if I am missing something obvious.
Yep, I was making sure you were paying attention. Now write some force balances.
Ok, I'm going to bed. My advice for now. Do a force balance and start taking moments and write down your results.
I made a mistake, the angle was nto given so I'm going to go with the traditional orientation of the axes to simplify things.
sumF(x) = W(man)-W(ladder)+N=0
sumF(y) =F(wall)-f=0
Alright, thank you
guys...the answer is simple...
white...u r right that the normal force of the floor would be equivalent to the 2 vector weights pointing downwards...they would cancel off...the normal force of the wall would be equivalent to the frictional force caused by the normal force of the floor...so i assume u know how to get 2 equations from wut i said above...now one must consider torque...the center of gravity of the ladder is assumed at the mid. of ladder...hence, find the torque exerted by the center of mass of ladder...lenght would be half the total length...then let x be the distance at which the man is...find the torque for that...assume that pivot is at the normal froce place...eases things...find the torque of the normal force at the wall...equate these qunatities together...u would get 3 euqations all toether...and make ur answer in terms of x...
and please at the static fricion.since this sis the pont when he laddder is abo slip
about to slip i mean
Can you stop writing like a 4-year old?
Thank you guys, this is wha tI was thinking. I'm going to work it out later today. Thanks!
  • · Replies 20 ·
