Calculating Gear Ratios With Restrictions
  • Thread starter Thread starter DarthRiko
    Gear Ratios
The discussion centers on the impossibility of achieving an exact 1:60 gear ratio using gears with 14, 34, and 84 teeth. The prime factorization of these numbers reveals that they cannot produce the required ratio due to the absence of a factor of 5 in their composition. The closest approximation achieved is 7:612, which results in a ratio of approximately 1:87.43. The conclusion emphasizes that without gears with teeth numbers that are multiples of 5, precise timing in a K'nex clock is unattainable.
  • Understanding of gear ratios and their calculations
  • Familiarity with prime factorization
  • Basic knowledge of K'nex building techniques
  • Experience with mechanical clock design principles
  • Research advanced gear ratio calculations using multiple gear sets
  • Explore alternative gear designs that include multiples of 5
  • Study the mechanics of K'nex clock construction
  • Learn about gear train configurations and their impact on timing accuracy
This discussion is beneficial for mechanical engineers, hobbyists building K'nex models, and anyone interested in precision timing mechanisms in clock design.
DarthRiko
I have three sizes of gears with 14, 34, and 84 teeth respectively.
I need an exact 1:60 gear ratio.
The problem I am finding is that 14:34 and 34:84 are very close to the same value.
14 and 84 is 1:6, but without a 1:10, that doesn't get me far.
The closest I can get is 7:612 (1:87.42857...)
I would greatly appreciate some help here. Assume I have unlimited gear and space.
For those of you wondering, I'm attempting to build an accurate K'nex clock.
Mathematics news on Phys.org
I need an exact 1:60 gear ratio. ...
It's simply impossible. Decompose your numbers in prime factors: 14 is 2x7, 34 is 2x17, 84 is 2x2x3x7, 60 is 2x2x3x5. When you couple two gearwheels with N1 and N2 teeth, their rotational speed ratio is the rational (Oh really? :smile:) number N1/N2; for a gear train, will be N1/N2*N3/N4*N5/N6..., i.e., with your gears, a number expressed by a fraction containing products of several 2,3,7 and 17 in both numerator and denominator. It will never be 60, at most some approximation.
If you cannot use gears with a teeth number multiple of 5, after days, months or years, your minute clock hand will be on 12 while the hours hand is between 1 and 2...
