Calculating Hg+2 Equilibrium Concentration
The discussion revolves around calculating the equilibrium concentration of Hg2+ in a solution initially containing Hg2+ and CN-. Participants are examining the stability constant for the complex ion [Hg(CN)4]2- and its implications for the equilibrium calculations.
  • Homework-related
  • One participant presents an equilibrium calculation using the ICE method but expresses uncertainty about the accuracy of their result.
  • Another participant questions whether 'K instab' refers to the equilibrium constant (Keq), seeking clarification on terminology.
  • A different participant suggests that the empirical formula for the combination of Hg2+ and CN- is Hg(CN)2, challenging the product used in the equilibrium expression.
  • One participant confirms the use of [Hg(CN)4]2- in their calculations, indicating a belief that the ICE table was set up correctly.
  • Another participant notes that the stability constant for Hg(CN)4 is in the range of 1042, implying a high stability for the complex.
Participants express differing views on the correct product for the equilibrium and the interpretation of the stability constant. There is no consensus on the setup of the equilibrium expression or the accuracy of the calculations presented.
Participants have not resolved the assumptions regarding the correct complex ion involved in the equilibrium or the implications of the stability constant on the calculations.
XTEND
Calculate the concentration of Hg+2 at equilibrium in a solution that is initially 0.10M in Hg+2 and 0.50M in CN-.
K instab for [Hg(CN)4]2- = 3.0 x 10 -42
K instab
[Hg(CN)4]2- --> Hg2+ + 4 CN- Initial Conc (M) 0 0.10 0.50 Change x -x -4x Equilibrium x 0.10 - x 0.50 – 4x Kinstability = [Hg2+][CN-]4 [Hg(CN)4]2- 3.0 x 10-42 = (0.10 - x)(0.50 – 4x)4 x 3.0 x 10-42 x = (0.10 - x)(0.50 – 4x)4 3.0 x 10-42 x = (0.10 - x)[(0.50 – 4x)2]2 3.0 x 10-42 x = (0.10 - x)(0.25 – 8x – 16 x2)(0.25 – 8x – 16 x2) 3.0 x 10-42 x = (0.10 - x)(0.25 – 8x – 16 x2)(0.25 – 8x – 16 x2)
answer so far: x= 0.029507
? can't get any further, think this calculation may be off
Does 'K instab' simply mean 'Keq?
The empirical formula of the simplest combination of the Hg2+ ion and the CN- ion is Hg(CN)2. Are you sure you've got the right product in that equilibrium?
I thought I set up the ICE method correctly?
Is it not [Hg(CN)4]2?
Yes same as K instab
Redo the ice table with Hg(CN)2 .
1042 is a range for stability constant for Hg(CN)4.
