Calculating Impedance in an RLC circuit
The discussion focuses on calculating the impedance across points ab in an RLC circuit with given values for frequency, inductance, resistance, and capacitance. The circuit configuration includes a series inductor and capacitor in parallel with a resistor. Initial calculations for capacitive and inductive reactances yielded incorrect impedance results, highlighting the need to treat the reactances as parallel components rather than simply summing them. The correct approach involves using complex impedance calculations, leading to a final impedance of approximately 0.504 Ω with a phase angle of -59.7°. The conversation emphasizes the importance of accurately interpreting circuit layouts for impedance calculations.
lpau001
Calculate the impedance Zab across ab.
w=0.75 Hz
wo=1 Hz.
L=1 H
R=1 Ohm
C=1 F
Inductor and Capacitor are in series, and together are in parallel with the resistor.
circuit looks like a capital A, but square on top, and rotated 90 degrees clockwise.. if that makes sense.
Zeq=sqrt(R2 +(XL-XC)2)
XC=1/(wC)
XL=wL
Using the equations above, I found XC to be 4/3 and XL to be .075.
inputting those in the impedance equations, I get
Z=sqrt(12 + (4/3-.75)2)
which is 1.1577 which is wrong..
If I understand your circuit layout, you've got a resistance in parallel with a reactance (the net result of the sum of the capacitive and inductive reactances). You don't just sum them to get the result, they combine like parallel resistances.
It might be easier to use the complex form for the impedance and do the math.
Zr = 1Ω, Zx = -0.583jΩ, then the net impedance is
Z = Zr*Zx/(Zr + Zx)
Z = Zr*Zx/(Zr + Zx)
I actually did try this in an earlier attempt, because I thought this was right, but apparently not.
1/Z=1/Zr + 1/Zx
I'm stuck, and I actually ran out of attempts on the HW, but this is more out of curiosity now than anything.
Thanks, Gneill
Z = Zr*Zx/(Zr + Zx)
= 1*(-0.583j)/(1 + -0.583j) Ω
= -0.583j/(1 - 0.583j) Ω
Normalizing,
= 0.254 - 0.435j Ω
This has magnitude |Z| = 0.504 Ω, and phase angle -59.7°
11K
