Calculating Magnetic Field at Point P from a Short Current Element
mortymoose
[/B]
A short current element dl⃗ = (0.500 mm)j^ carries a current of 5.20 A in the same direction as dl⃗ . Point P is located at r⃗ = ( -0.730 m)i^+ (0.390m)k^.
Find the magnetic field at P produced by this current.
So basically what they are asking me for is the x, y, and z components of dB.
dB= mu0/4pi * (I*(dl x r^)/r^2)
B=Bxi^ +Byj^ +Bzk^
dB= 10^-7 * 5.2A *(1.95*10^-4m i^ +3.65*10^-4m k^ )/r^2
So, I cross multiplied dl and r^, now I am completely lost. I don't understand how I am supposed to find the x,y, and z components.
The idea i have is:
use the r^ as r and square it and finish the above equation and solve for dB, and then whatever i^ and k^ component is in the answer is equivalent to my x and z?
So dB=(-2.67*10^-4)i^ +(4.86*10^-10)k^
i^= x k^=z and y=0=j^But i get this answer wrong. Can anyone direct me into the right direction or tell me what I did wrong?
Looks right.
Yes. ##\vec r^2=\vec r.\vec r=|\vec r|^2##.
I don't understand how you get these numbers (nor the minus sign). Please post the intermediate steps.
They don't tell the location of the current element. You have assumed it is at (0,0,0). OK. Gotta assume something.
But your answer of dB=(-2.67*10^-4)i^ +(4.86*10^-10)k^ has a sign error. (I didn't check your numbers).
haruspex said:
Looks right.
dB= 10^-7 * 5.2A * (1.95*10^-4 i^ + 3.65*10^-4 k^)/r^2
r^2= (-0.73i^ + 0.39k^)^2 = (0.5329 i^ + 0.1521 k^)
Then i plug r^ in...
dB= 1.9027*10^-10 i^ + 1.248*10^-9 k^
Does this look better? I think i must of multiplied something wrong the first time maybe?
This line makes no sense. r^2 is a scalar, not a vector. But the final result might be OK.
Your previous mistake was to say j x -i = -k.
As rude man points out, this is wrong.
##(x \vec i+y\vec j)^2=x^2\vec i.\vec i+2xy\vec i.\vec j+y^2\vec j.\vec j=x^2+y^2##
##\vec i.\vec i=\vec j.\vec j=1## (dot product is a scalar, and these are unit vectors).
##\vec i.\vec j=0## ( these vectors are perpendicular).
