Calculating Maximum Load Capacity of a Hydrogen-Filled Balloon
The discussion revolves around calculating the maximum load capacity of a hydrogen-filled balloon with a specified radius and mass of the balloon material. Participants are exploring the relationship between the balloon's volume, the buoyant force, and the weight of the balloon and its contents.
  • Participants are attempting to calculate the volume of the balloon and the mass of the air displaced to determine the buoyant force. Questions are raised about the relevance of the balloon's radius and the mass of the balloon material in the calculations.
There is an ongoing exploration of the principles involved, including Archimedes' principle. Some participants are clarifying the calculations and relationships between the buoyant force, the weight of the displaced air, and the weight of the balloon and its contents. Multiple interpretations of the problem are being discussed without a clear consensus.
Participants are working under the constraints of the problem's parameters, including the densities of hydrogen and air, and the mass of the balloon material. There is uncertainty regarding the correct application of these parameters in the calculations.
anyone1979
Help with a problem:
A spherical, hydrogen-filled balloon has a radius of 12 m.
The mass of the balloon plastic and support cables is 196 kg.
What is the mass of the maximum load the balloon can carry?
(Density of hydrogen = 0.09 kg/m^3; density of air = 1.25 kg/m^3)
I do not know where the radius of the balloon ties in but this is what I have so far.
V = mass/density = (196 kg)/(0.09 kg/m^3) = 2.2 x 10^3 m^3
mass of displaced air = (2.2 x 10^3 m^3) x (1.25 kg/m^3) = 2.9 x 10^3 kg
weight of displaced air = (2.9 x 10 ^3 kg) x (9.8 m/s^2) = 28420 N
maximum load the balloon can carry = (28420 N) / (9.8 m/s^2) = 2900 kg
Is that about right, or do I need to include the area?
If I need to include the area of the balloon, how do I do that?
1. Before moving on to the next questions, tell us whose volume is this V?
2. Do you feel that the volume of the Hydrogen gas itself has anything to do with the max load?
3. Please write Archimedes' Principle along with these so that we can proceed further.
Thanks for the reply. Archimedes' principle states: When a body is completely or partially immeresed in a fluid, the fluid exerts an upward force on the body equal to the weight of the fluid displaced by the body.
When a balloon floats in equilibrium in air, it's weight (including the gas inside it) must be the same as the weight of the air displaced by the balloon.
To answer you second question, I think so. To move upward, it should be the (mass of the displaced air) * (gravity).
To move downward, it should be the (mass of the hydrogen) * (gravity) right?
so, If these balance, then we find the max load the buoyant force can support.
If you understand all this, why did you write > V = mass/density = (196 kg)/(0.09 kg/m^3) = 2.2 x 10^3 m^3 <?
The vol of the balloon is given via the radius. Vol of air displaced is known, and so the buoyant force is known. The mass of the balloon plastic etc and the H gas is known.
These won't balance. The buoyant force will be more. What do you think the answer should be?
Where will the mass of the balloon plastic etc.. tie in?
if ... V = (4 pi / 3)(radius^3) = 7.24 * 10^3 m^3 Then...
mass of displaced air = (7.24 * 10^3 m^3) * (1.25 kg/m^3) = 9.1 * 10^3 kg
weight of displaced air = (9.1 * 10 ^3 kg) * (9.8 m/s^2) = 89180 N
I am a little confused now...
B = Buoyant force = 89180 N, acting upward. (Already found.)
W = weight of H gas + 196 kg(plastic, rope etc) = weight of balloon, acting downward (Find it.)
MAx load it can carry now = B-W.
(Please check your arithmetic before replying.)
Thanks for clearing that up. I just got to add the 196 kg.
Weight of balloon = density of hydrogen * V * gravity + 196
then the buoyant force minus the weight of the balloon will give me the max load.
9K
  • · Replies 62 ·
