Calculating Minimal Distance between Two Protons in Motion
The problem involves calculating the minimal distance between two protons, one of which is in motion towards a stationary proton. The context includes concepts from electrostatics and conservation laws in physics.
  • Participants discuss conservation of energy and momentum as potential approaches to the problem. There are questions about the assumptions regarding the motion of the second proton and how to incorporate distance into the equations.
Participants are exploring various conservation laws, including energy and angular momentum, while questioning the fixed position of the second proton. Some guidance has been offered regarding the use of conservation laws, but there is no explicit consensus on the approach to take.
There is a discussion about the assumptions regarding the motion of the second proton, with some participants suggesting it is fixed while others consider the implications of this assumption on the conservation laws being applied.
kuokius
A proton is moving at speed v from infinity toward a second stationary proton, as shown below. Determine the minimal distance between them.
http://s27.postimg.org/lmw3d21j7/Untitled.png
[tex]W = \frac{kq_1q_2}{r}[/tex]
[tex]E_k = \frac{mv^2}{2}[/tex]
Let's say that the minimal distance between two protons is x and at that moment their speeds are v_1. Then the initial energy would be E_1 and the final E_2:
[tex]E_1 = \frac{mv^2}{2}[/tex]
[tex]E_2 = \frac{ke^2}{x} + mv_1^2[/tex]
According to the law of conservation of energy: [tex]E_1 = E_2[/tex]
And now I just don't know how to find the speed v_1.
Can you think of any other conserved quantities?
Maybe an electric field or potential will remain constant at some point?
So, I see that I can use conservation law of linear momentum. But how to include a given distance r?
good
that was my problem too...
been away from solving any of these for, well 50 plus years,
amazing I can remember my own name!
https://en.wikipedia.org/wiki/Momentum#Conservation
"If the velocities of the particles are u1 and u2 before the interaction, and afterwards they arev1 and v2, then
Think about whether you can use these as a second set of equations...m's are all the same, only proton is moving initially, right?? two equations, two velocity unknowns
the stationary proton accelerates, reaches some velocity which you'll know...
so you'll need another equation relating velocity to minimal distance...unsure what that is
Is the second proton free to move or is its location fixed? I think you're supposed to assume the latter.
Of course...duh!
thank you
Yes, the second proton is fixed. Then I suppose I could use conservation law of angular momentum.
Yes, but only if you choose the axis carefully.
Linear momentum is not conserved because the second proton is being held in place by some external force. How do you avoid that being a problem for angular momentum?
Let's say I choose an axis going through the second proton which is fixed. Vector of electrical force creating external forces momentum goes through the axis, so the momentum of external forces equals zero. Then the initial and final angular moments would be:
[tex]L_i = mvr[/tex]
[tex]L_f = mv_1x[/tex]
[tex]L_i = L_f[/tex]
[tex]\frac{mv^2}{2} = \frac{mv_1^2}{2} + \frac{ke^2}{x}[/tex]
Am I right?
Am I right?
Looks right.
This doesn't really make sense. I know what you're trying to say, but what you've written is nonsense.
  • · Replies 45 ·
  • · Replies 28 ·
