Calculating Mutual Inductance of Two Rectangular Loops
7 replies · 5K views
kseniya
I am a student of the electrical engineering in the university of Munich. I tried to solve a homework but I have some difficulties.
I have tried to use different methods. unfortunately, unsuccessfully.
I will be very glad if you could help me. in fact I wanted to calculate the mutual inductance of two rectangular loops ( very thin wire) . both loops are identical and lie in the same plane. (Length c; wide b, a-b is the distance between them …see picture please) only in one of both loops flows strom I.
I have tried to calculate directly with the Neumann's formula, however, I get a very difficult integral, impossibly to solve:-( I have also tried to calculate the B field only in the center of the second rectangle (I’m not sure if that’s right). however, ordinarily the B field of (the first rectangle) must be calculated everywhere and then its flux in the second rectangle)
I have tried over again to accept the first rectangle as two very long thin wires and then to calculate the B field of both wires and then their flux in the secod rectangle, however, I do not know if the approach is right. as said I am a little bit lost and need your help.:cry: I will be glad if I will get a feedback from you .
I apologise for my bad english:blushing:http://www.imagup.info/images/03/1181839013_induc.jpg .[/URL]
I wish you a nice day!
Kseniya
try right subforum.
and write down more of what you have done to solve this, maybe you started out right and then did something wrong.
thank you for your tip malawi_glenn, i will try another sub-forum.
it will be so nice from you if you can move it to the intro Physics forum, I'm new hier. may be it's better.
thank you Doc Al
i have the same problem with ksenya...i tried to solve it but i am not sure...
please help me..
ti have tried o calculate the B field of both wires and then their flux in the second rectangle, however, I do not know if the approach is right...i am not sure that the uppon and the under wires have a flux in the second rectangle...i think that only the flux of the right and the left one must be calculated...please help me
