Calculating Normalization Factor for 1s Atomic Orbital of H
  • Thread starter Thread starter geronimo123
    Normalization
geronimo123
Hi all! I hope somebody is able to help me on my way with this question.
I have been asked to show that the Normalization factor for the 1s atomic orbital of H is 1/(\Pi a_o^3)^\frac{1}{2}. The wavefunction is \psi(r) = N exp(-r / a_o)
I'm given dt = r^2 sin \Theta and dr d\Theta d\Phi and \int_{0}^{\infty}x^n e^{ax} dx=n!/a^n+1
I must admit I'm clueless which direction to go. It was mentioned to me, that squaring the wavefunction is the first step, but I cannot arrive at the given constant. Am I starting off on the wrong foot?
Thanks for any input, in advance.
geronimo
I have been asked to show that the Normalization factor for the 1s atomic orbital of H is 1/(\xi a_o^3)^\frac{1}{2}. The wavefunction is \psi(r) = N exp(-r / a_o)
I'm given d \Tau = r^2 sin \Theta;dr d\Theta d\Phi and \int_{0}^{\infty}x^n\e^-ax\dx=n!/a^n+1<br /> <br /> I must admit I'm clueless which direction to go. It was mentioned to me, that squaring the wavefunction is the first step, but I cannot arrive at the given constant. Am I starting off on the wrong foot?<br /> <br /> Thanks for any input, in advance.<br /> <br /> geronimo
<br /> You have all the pieces in place.<br /> Just impose \int_0^\infty dr r^2 \int_0^{2 \pi} d\phi \int_0^\pi sin(\theta) d\theta \,\,N^2 e^{-2 r /a_0} =1 and solve for N.
I must admit that my integration is not what it used to be. I'm taking some physical chemistry night classes where this problem was set. How might one initially solve for N?
The \phi integral just adds a factor of 2\pi, change variables in the \theta integral to x=\cos(\theta) and then it becomes a lot nicer.
Good luck.
Eoin Kerrane.
the theta integral gives 2. The phi integral gives 2 pi. For the r integral, you have a formula. just compare the r integral to the formual you have, term by term (what is n? etc) and you will have the result of the r integration. Then you have N^2 times an expression = 1 and you solve for N
Super guys, I have managed it finally thanks to your help. Best regards
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
