Calculating Object Distance for Magnified Real and Virtual Images
  • Thread starter Thread starter iurod
    Converging Lens
To determine the object distance for a 50.0-mm-focal-length lens producing a magnified real image at 2.00x, the magnification formula m = -di/do is applied, leading to the conclusion that do = -di/-2. For a real image, the image distance (di) must be positive, resulting in a recalculation that shows di = +100mm, leading to do = +50mm. However, the book states the answer should be +75mm, indicating a potential miscalculation. The discussion emphasizes that for a real image, the magnification must be negative, and further clarification on the lens equation is sought to resolve the discrepancy. Understanding the relationship between object distance, image distance, and magnification is crucial for accurate calculations.
iurod
(a)How far from a 50.0-mm-focal-length lens must an object beplaced if its image is to be magnified 2.00 x and be real? (b)What if the image is to be virtual and magnified 2.00x?
m = -di/do
1/do+ 1/di = 1/f
m = -di/do solve for do
do = -di/2
Now i have to use the lens equation:
1/do+ 1/di = 1/f
-(2/di) + 1/di = 1/f
-1m/di = 1/f
di= -1m/(1/f)
di = (-1 x 2)/(1/50mm)
di = -100
This is what i got for part a, and I know it is totally wrong because to be a real image di>0 which is not what i got.
any help will be greatly appreciated. Thanks!
The real image is inverted, so the magnification is negative, -2. ehild
Is a real image upright or inverted? What does that tell you about m?
EDIT: oops, ehild beat me to it.
so for this part:
1/do+ 1/di = 1/f
-1m/di = 1/f
di= -1m/(1/f)
di = -100
it should be:
di= -1m/(1/f)
di = (-1 x -2)/(1/50mm)
di = +100mm
so do = -di/m = -100/-2 = +50mm
in the back of the book it says the answer should be +75mm.
iurod said:
so for this part:
1/do+ 1/di = 1/f
You are still saying that do=-di/2. That will not be true, according to the help we gave you earlier.
A real image is inverted and m should be negative
m= -di/do
-2= -di/do
do= -di/-2
If this is correct then
1/do+ 1/di = 1/f
-2/-di + 1/di = 1/f
hmmm I'm stuck after this
Any more advice on this?
Thanks!
m= -di/do
-2= -di/do
do= -di/-2
Correct, but you can simplify "-di/-2"
1/do+ 1/di = 1/f
-2/-di + 1/di = 1/f
You are told what f is. Use that value, then you can solve the equation for di.
9K
