Calculating pH and Ionization of Aspirin Solutions
  • Thread starter Thread starter sci0x
    Ionization Ph
To calculate the pH of a 0.2M aspirin solution, the formula pH = -log[H+] is used, with [H+] derived from the equation [H+] = √(Ka * c), resulting in a pH of approximately 3.52. The percent ionization can be determined using the formula √(Ka/c), which quantifies how much aspirin dissociates in solution. Adding 0.01M hydrochloric acid increases the concentration of H+, affecting the ionization of aspirin due to the common ion effect, which suppresses further dissociation of the weak acid. The new pH and percent ionization must be recalculated using the updated H+ concentration from the combined effects of aspirin and hydrochloric acid. This discussion emphasizes the calculations and qualitative effects of ionization in weak acid solutions.
sci0x
Question: Aspirin is a weak acid.
(a) Calculate pH of 0.2M solution of aspirin at 25 degrees celsius (Ka = 3.0 x 10^-4 at 25 degrees celcius).
(b) Determine the percent ionisation
(c) Explain qualitatively the effect of adding 0.01M hydrochloric acid to the aspirin solution.
(d) Calculate the pH of the resulting solution
(e) Determine the percent ionisation of the aspirin under these conditions
hmmm
well formula goes.. pH=-log[H+]
am not sure what about aspirine...i am is Ka also meant as concentration of H+ ??
if yes ...then
pH=-log[H+]
pH=-log(3.0 x 10^-4)=3.5228
and it is acid...but wouldn't say that weak
Sci0x : Please read the forum guidelines for getting help with schoolwork. See my signature.
here is the most effective way with which u must proceed---
1) the conc is given as .2 M and ka is given so find the H^+ conc using the formula [H^+] = \sqrt{K_a * c}
2) percentage ionisation is given by the formula \sqrt{\frac{k_a}{c}}
3)Explain common ion effect
4) due to addition of hydrochloric acid the conc of H+ will now be 0.01 + the conc of H+ u got in the 1st question
5) repeate the 2 question but now with the new conc of H+ note use formula \frac{[H^+]}{c}
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
