The discussion revolves around calculating the pH and pOH of a Silver Nitrite (AgNO2) solution when 0.1g is added to 100 mL of water. Participants explore the dissociation of NO2- ions and their impact on the acidity or basicity of the solution, considering the relevant equilibrium constants.
- Homework-related
- Mathematical reasoning
- Technical explanation
- Debate/contested
- One participant notes that NO2- ions will participate in an acid-base reaction with water, suggesting the solution will be basic.
- Another participant questions the significance of the number of NO2- ions present and their effect on pH.
- A participant proposes that despite the small Ksp, the equilibrium will shift to the right due to the presence of NO2- ions reacting with water, resulting in the formation of HNO2 and OH-.
- Calculations are presented regarding the concentration of Ag+ and NO2- ions, leading to a proposed pOH and pH based on these values.
- There is a correction regarding the initial concentration of NO2- ions, with one participant stating it should be .006499M instead of a previously calculated value.
- Another participant verifies the calculation of Kb using the relationship Kb = Kw/Ka, expressing uncertainty about potential decimal place errors in previous calculations.
- One participant suggests that the pH of the solution will be close to neutral, estimating it to be between 7 and 8.
Participants express differing views on the expected pH and pOH values, with some calculations leading to significantly basic values while another participant suggests a near-neutral pH. The discussion remains unresolved with multiple competing views on the calculations and their implications.
Participants have not reached consensus on the correct approach to calculating pH and pOH, and there are unresolved questions regarding the assumptions made in the calculations, particularly concerning the solubility and dissociation of AgNO2.
