Calculating Position and Angle of a Particle on a 2D Plane
  • Thread starter Thread starter RoganSarine
    Coordinate
The discussion revolves around a problem involving the motion of a particle on a 2D plane, specifically focusing on its acceleration, position, and angle of travel. The particle's acceleration is given as a function of time, which complicates the application of standard kinematic equations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the implications of non-constant acceleration and question the applicability of standard equations for constant acceleration. Some participants suggest integrating acceleration to find velocity and position, while others express uncertainty about how to proceed with the problem.
There is an ongoing exploration of the problem, with some participants providing hints about integration as a potential approach. The original poster acknowledges the need for guidance and expresses a desire for further assistance in understanding the problem.
Participants note that the problem may not have been assigned, leading to a discussion that is more exploratory in nature. There is also mention of a basic understanding of calculus, which may influence the level of discussion regarding integration.
RoganSarine
"Simple" Coordinate Problem
The following happens on a 2D X-Y Plane.
A particle accelerates at {3t m/s2}i + 4t m/s2}j where t = seconds
At t = 0, the position of the particle is {20.0 m}i + {40.0m}j
At t = 0, the velocity of the particle is {5.00 m/s}i + {2.00 m/s}j
At t = 4,
(a) What is the position vector in unit-vector notation
(b) What is the angle between its direction of travel and the positive direction of the x-axis
dx = Vox*t + .5(a)t^2
Dy = Voy*1 + .5(a)t^2
dx = 5(4) + .5(3(4)) (4)^2
dx = 20 + 6(16)
dx = 116
Dy = 2(4) + .5(4(4)) (4)^2
Dy = 8 + 8(16)
Dy = 136
Therefore, it's position vector should be
P = {136 m}i + {176 m}j
If we remember to add on the initial displacement.
The answer is {72.0 m)i + {90.7 m}j
The relevant equations you cited are for constant acceleration. You do not have a constant acceleration here.
Huh... Right. True. However, I don't ever remembering having to deal with anything that isn't constant acceleration.
Any hints on what to start with?
First you should do is check that you have the problem correct. If it is correct as written, I suspect that you have learned something about integration.
Yes, the problem is correct.
We have actually learned nothing about integration specifically, but I do know the basic calculus for integration and have a basic understanding of it.
But I do not see how it applies.
Basically, this question was not even assigned to us I don't think, I am simply going through all the questions my text gives me in the section, so... If you could give me a giant push or something, I'd appreciate it.
You know the acceleration as a function of time and the initial velocity. Acceleration is the derivative of velocity, so integrating acceleration with respect to time will yield velocity as a function of time. Integrating velocity will yield position.
So in theory, wouldn't
ax(t) = 3t
vx(t) = (3/2)t^2 + c
px(t) = (3/6)t^3 + ct + d
If vx(0) = 5
then
vx(0) = (3/2)(0)^2 + c
5 = 0 + c
c = 5
vx(t) = (3/2)t^2 + 5px(t) = (3/6)t^3 + ct + d
px(t) = (3/6)t^3 + 5t + d
px(0) = 20
px(0) = (3/6)(0)^3 + 5(0) + d
20 = 0 + 0 + d
d = 20
Therefore:
p(x) = (3/6)t^3 + 5t + 20
p(4) = (3/6)(64) + 20 + 20
p(4) = 32 + 40 = {72 m}i
Which... is the answer for the x coordinate. Thanks for the hint -- I knew it couldn't have been too hard once again just tired.
  • · Replies 17 ·
